slow - slower ---> tie fighter from Lucas Arts
Reply 20 of 26, by wd
Rank DOSBox Author
DOSBox Author
Sad enough some people are too stupid to understand mounting and recommend
to mount their whole harddisk, and then go putting it into a tutorial...
Reply 21 of 26, by LaL
Boy, you sure provide constructive feedback.
However, I adjusted the tutorial accordingly.
aL
Reply 22 of 26, by wd
Rank DOSBox Author
DOSBox Author
Well it's typed out in explicit letters that you should not do it, can't be more constructive.
Still has the same mounting line there (+warning), but thanks for trying.
Reply 23 of 26, by robertmo
luckily those mountings won't work 😉
Reply 25 of 26, by LaL
Okay, I linked XBCD 0.2.6 as well.
The mounting does indeed work for me (in 0.72) and game would not run without it, but I guess that's just because I did not install the game in DOSBox.
aL
Reply 26 of 26, by IIGS_User
Which is preferred to do. 😉
Klimawandel.
