Win 3.11
First post, by chootastic
This is a slightly strange request, i know. But i managed to get Windows 3.11 running in Dosbox. Now I know Dosbox is capable of emmulating a serial modem... I was wondering if anyone knew which type, as i can find nothing in the documentation.
Basically i want to install the correct drivers, so i can get the internet working in my Win 3.11 Vm.
Current Config:
dosbox ver 0.71
win ver XP Pro Coporate
[sdl]
fullscreen=false
fulldouble=false
fullresolution=1024x768
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=svga_et4000
captures=capture
memsize=64
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=auto
cputype=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=22050
[gus]
gus=false
gusrate=22050
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
serial1=modem
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=true
[autoexec]
mount c: c:\dbx\
mount z: d:\
c:
echo off
cls
echo dosBox 0.73
echo Drives mounted as:
echo c: = c:\dbx\
echo z: = d:\
Reply 2 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
AND you need to install Win3x on a disk image and not as outlined in my guide Windows 3.1x DOSBox Guide
The small written text at the end of the guide DOES apply though 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 7, by chootastic
Ok, progress so far.
*Installed the modded DOSbox version.
*Installed Winpcap
*Configured Winpcap to confer with my TP-Link Wireless adaptor
Now im getting this:
Reply 4 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Google suggests it's a Winpcap issue. Maybe it will work with future versions. You could try administrator mode if not done already or a different network card.
1+1=10
Reply 5 of 7, by Dominus
DOSBox Moderator
h-a-l you might need a special forum section for questions on the megabuild or a forum section labeled "officially unsupported dosbox builds" for all others that offer unofficial builds 😀
Reply 6 of 7, by chootastic
Ok bugger! 🤣 - never mind, it was just a silly idea. As for using a different network card, i dont have one, so never mind. Thanks for your help guys!
Reply 7 of 7, by valnar
On a related note.... H.A.L, I look forward to your next megabuild. 😉
