First post, by nikiniki
Hi
Shadow Warrior freezed after I defeated the first boss.
I selected 800x600.
The game runs fine if 320x200 is selected but I'd like to use higher resolution.
Reply 1 of 12, by eL_PuSHeR
[Moving to the Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 12, by nikiniki
Dosbox 0.73.
Reply 4 of 12, by robertmo
where have you got your dosbox from?
what is your Operating System?
what are your PC specifications?
post your exact mountings
post what is written after you mounted
post content of "DOSBox Status Window" before running the game
enclose your dosbox's config file
Reply 5 of 12, by nikiniki
The dosbox webpage
windows vista
Vaio 4gigs, laptop
c:\dosbox\dosbox C:\ShadowW -conf dosbox.conf
see the picture
Reply 6 of 12, by nikiniki
Here the picture
Reply 7 of 12, by nikiniki
Reply 8 of 12, by wd
Rank DOSBox Author
DOSBox Author
Obviously that's no config file from a 0.73 installation, and then it doesn't
look like you installed it correctly/kept the right mountings.
Reply 9 of 12, by nikiniki
Hi
I created go.bat file to run Shadow Warrior.
In GO.BAT
When I erased dosbox.conf from SW directory, a new one was created at c:\users directory not from the game. I'd like the config was created in the game directory like Dosbox did with screenshots.
Also I changed svga_s3 to vesa_nolfb
Now, the graphic look better
But the game still crashes in the boss battle.
Here the dosbox.conf
Reply 10 of 12, by nikiniki
Reply 12 of 12, by nikiniki
I just found the problem. Because you play SW in higher resolution, it needs more memory.
In config file, change memsize=16 to memsize=32
Shadow Warrior works fine this way.
