First post, by eL_PuSHeR
Ultimate Packer for Executables v3.07
Changes in 3.07 (08 Sep 2010):
* win32/pe: fixed relocation handling for files with *no* TLS callbacks
[severe bug introduced in 3.06]
UPX Changelog
WinUPack 0.39 final (great compression ratio)
KKrunchy 0.23alpha2 (Intended to pack 64KB intros) (Thanks bugsbugger)
ANDPakk2 0.18 -> Download
(Another one for the demoscene) (Thanks bugsbugger)
UPack
Enjoy! 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 1 of 7, by eL_PuSHeR
UPX was updated.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 3 of 7, by eL_PuSHeR
UPX 3.05 is released.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 7, by tikbalang
aPACK.com
"16-bit DOS executable compressor. aPACK compresses the file while keeping it executable. aPACK uses advanced compression heuristics and tricks to achieve the best compression ratio. aPACK has ranked as one of the best 16-bit DOS executable packers for years."
http://www.ibsensoftware.com/products_aPACK.html
ESS PCI DOS Drivers
_________________
Reply 5 of 7, by eL_PuSHeR
Cool. I was a beta tester for older aPack... 😎
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 7, by peterferrie
The aPLib code compresses better than the routines in aPack do.
The DOS compression market was huge. :-) Crunch, LZExe, PKLite, WWPack, ...
For Windows, ANDpakk2 was updated to 0.18.
Reply 7 of 7, by eL_PuSHeR
Thanks for the heads up on ANDPakk2.
Intel i7 5960X
8 GB DDR4 (2100)
