Master of Magic
First post, by NYPD
I posted this first in the Sound section by mistake. Sorry about that. I think this is where it goes.
Hello
I recently bought a bunch of classic games at a flea market. I read up on how to get MoM to run and got your great DosBox tool.
Now my old school memory on how to cd \ (Type in the proper lines to get a dang game to run) has left me completely.
Can someone please post here what I have to do EXACTLY to get Master of Magic to run? Please?
Do I have to start DosBox first and then type in a dos line?
Also I downloaded the latest version of DosBox do I need to update it or something?
By the way I have a p4 2 gig processor, a geforce 4 128 vid card, not sure sound card, 1 gig of ram, and running windows 2000 pro.
Thanks,
NYPD
Reply 1 of 2, by Runenklinge
hello,
have you installed / unzipped MoM yet? If not,do so,and rememer the directory you install it to.
Next,start DosBox.exe from the DosBox directory.A Dos screen will appear.Now type: mount c c:\MoM (if c:\MoM is the directory you installed to).Now,type c: .You're now in the MoM directory and can start the game.If it runs too slow,press Ctrl+F12 to increase CPU usage,or Ctrl+F8 to increase the number of frames skipped.
Reply 2 of 2, by Nicht Sehr Gut
Originally posted by NYPD I posted this first in the Sound section by mistake. Sorry about that. I think this is where it goes.
Yes, and the older one has been purged.
http://emlab.berkeley.edu/sst/basic.dos.html
http://www.easydos.com/dosindex.html
After you've read the README that comes with DOSBOX. Try looking at these posts for some background:
showthread.php?threadid=605&highlight=Master+Magic
showthread.php?threadid=779&highlight=Master+Magic
showthread.php?threadid=1094&highlight=Master+Magic
showthread.php?threadid=1641&highlight=Master+Magic
showthread.php?threadid=1766&highlight=Master+Magic
showthread.php?threadid=1860&highlight=Master+Magic
showthread.php?threadid=2032&highlight=Master+Magic
Yes. Read the README that comes with it. Basically, DosBox acts as a "Virtual" DOS PC that uses your real drives and directories. For example, if your "Master of Magic" is in C:\MPS\MOM, you would type something like like MOUNT C C:\ (which makes your C: drive available to DosBox), then C: to switch to the C: drive, then CD MPS\MOM to switch to the game directory.
From there you you would run setup to match up with DosBox's specifications, then run the game.
If you have the latest version; then, by definition, you don't need to update it.
