"For" command in dosbox?
First post, by arfy
Ok, I have a question, and just need some pointers here. I just tried to play a bunch of cmf files, using good old playcmf, and, as far as I can tell, it doesn't support something like, playcmf c*.cmf. So, next thought, let's do a for loop, you know, for %f in *c*.cmf) do playcmf %f... Pproblem? there doesn't seem to be a for command in dosbox, but hopefully I'm mistaken? If not, anyone got any workarounds? something on simtelnet or something?
thanks!
Reply 1 of 3, by Jorpho
The first thing that comes to mind is 4DOS, which apparently runs under DOSBox.
Reply 2 of 3, by arfy
indeed it does. thanks! Seems to work just fine for what I need, and in the process, I learnt that 4dos is now open-source and freeware. cool!
Reply 3 of 3, by rfnagel
Attached is a little something that you might wanna try, a frontend for PlayCMF. I've used this freebie for almost two decades now 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
