First post, by kapcon
one of my DOS programs creastes a configuration file while running, but if i try to run this program, i get this error: "file cannot be created DOS code 2" how do i fix this?
thanks
BeWell
dovid
Reply 1 of 4, by Davros
do you know what file is not being created ?
if so create an empty txt file with the same name and extension
if its config.cfg make sure it is config.cfg and not config.cfg.txt
then run your program
Reply 2 of 4, by kapcon
dear guardian,thanks i'll try that... btw, i like your avatar. i'm having trouble uploading one, any advice?
thanks
BeWell
dovid
Reply 3 of 4, by kapcon
i fixed my problem, but not via the text file. i unknowingly had another seession of that DOS program open but minimized, so the Config file could NOT be written to, since it was open. i'm guessing that Dos Code 2 means the file was open.
thanks
BeWell
dovid
Reply 4 of 4, by Davros
about your avatar
"It must be less than 120 pixels wide, 120 pixels tall, and 64 kB in size."
