First post, by yoxgit
i was just wondering if there is a way to show the menu bar of the game you are playing while using dosbox, the game i am trying to play really needs to use that menu bar and is unplayable without it
which game ?
Water flows down the stream
its for an dos version of an angband game
No idea what you are talking about, maybe you can post a screenshot how
it currently looks in dosbox, how it looks on a real pc and/or how you think
it should/could look like.
well i am a noob so i dont know how to post screen shots, but across the top of the game is a menu bar with things like file, window, options, and help. when i play a dos version of the game with dosbox this menu bar does not show up, because of this i cannot adust some of the settings of the game.
Is there another version of the game? Are you sure the game displays a menu
bar in the DOS version? As dosbox doesn't remove game content, so it's pretty
likely that your game does not have a menu at all.
How to create screen shots is in the readme, additionally you can play the game
non-fullscreen (in a window) and use the printscreen feature of your OS.
Is this game the one you are playing?
