First post, by barryNY
How do you pass command line parameters to a DOS program that is started up with a desktop shortcut?
Program works great from the shortcut icon when no parameters are specified to the DOS program. When a parameter is specified with the program, I just get the console.
I'm using Windows 7 (what a piece of garbage) running an older DOS communications program to a device via a USB to serial converter cable. All works great in the program's default mode.
Sorry if this is answered elsewhere, but I searched all documentation, online forum and tried everything I could.
Reply 2 of 5, by barryNY
The readme states how to send command line parameters to DOSBOX or to send a DOS command. I need the parameter sent to the DOS program itself.
dosbox "C:\DOSDIR\DOSPROGRAM.EXE" -exit -conf "C:\DOSDIR\DOSPROGRAM.CONF" -noconsole
This is an example of the shortcut icon Target command line. When I execute as above, it works great. But when I add the parameter "/com=3" to be passed to DOSPROGRAM, it aborts and just brings up the DOSBOX console.
dosbox "C:\DOSDIR\DOSPROGRAM.EXE /com=3" -exit -conf "C:\DOSDIR\DOSPROGRAM.CONF" -noconsole
I've tried the -c command parameter, and many combinations and arrangements.
Thank you
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
How did you try the -c command?
And if that fails why don't you use the autoexec section of the conf when you already pass that along (instead of executing the program with dosbox)?
And most importantly, does the program work inside dosbox with the /com3 command?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by barryNY
The AUTOEXEC section worked. I didn't know that you could use that section to run the final program. The order of execution between AUTOEXEC and the command line parameters was confusing.
My commands in the Autoexec section are:
MOUNT C "C:\DOSPROGRAM"
C:
DOSPROGRAM /COM=4
EXIT
I found that the -noconsole parameter had to be left on the command line. I couldn't get it to work from within the conf file.
Otherwise, I'm 100% up and running. Thanks for your help!
Reply 5 of 5, by Dominus
DOSBox Moderator
you're welcome. The -noconsole switch is needed for the command line because it needs to be set right away, when Dosbox reads the conf file it is already too late 😀
