First post, by kawaiipikachu
I set up in the autoexec section of the Dosbox config file to automatically mount the floppy drive via the "mount a a:\ -t floppy" command.
The problem is every time I startup Dosbox I get this error message 3 times in a row & everytime I needed to clock on Continue.
It is annoying.
I wonder if there's a way to get rid of it without removing the command from the config file.
btw I also provided a screenshot as an attachment.
Reply 1 of 5, by eL_PuSHeR
Well, do you have a physical floppy drive with a disk inserted?
Try mounting a FOLDER like a floppy to see what happens.
mount a <anyfolder> -t floppy
Reply 2 of 5, by kawaiipikachu
I do have a physical floppy drive but one time I did notice the message dissapeard when I had a floppy inserted in it.
Reply 3 of 5, by eL_PuSHeR
That is possibly the reason. Windows is already saying "there is no disk..."
Reply 4 of 5, by kawaiipikachu
Yes that's what I'm thinking too aw well.
Is there any setting's I can change to prevent it from Popping up?
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
don't do the mount a a:\ if there is no floppy and the problem goes away.
Water flows down the stream
