First post, by mrugesh
Hello,
I've downloaded DOSBOX 0.74 and ran the C program. It works nicely but when I try to display it by pressing CTR+F9 it just shuts the DOSBOX down & comes out on the desktop.Then I have to again go into the DOSBOX and again repeat all the procedure of mounting and commanding.
What to do?How can this problem be rectified? [/b]
Reply 2 of 5, by mrugesh
I tried to do it.It also shows keyboard keys in mapping but don't know how to change.please ,if u can guide.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
the documentation of dosbox doesn't help ?
Water flows down the stream
Reply 4 of 5, by mrugesh
I followed the documentation but it didn't help.What to do? dosbox window just shuts down. also I try to run a C program by run tab it shows message "Not an EXE: Hello.LIB". what to do.
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
What to do?
Works fine here. Try again.
That's completely unrelated to dosbox. Read the manual of the compiler.
