Two SB16s are better than one?
Reply 21 of 33, by retro games 100
Interesting point that SquallStrife mentioned, about both cards trying to access port 388 for the OPL3. If the AWE64 can have this resource disabled, it would seem like a good choice for one of the two cards. Unfortunately, I can't remember if the ESS AudioDrive's "init" program can disable this 388 port resource.
Reply 22 of 33, by Mau1wurf1977
AWE64 can even change 388 to something else!
Usually 388 isn't an issue, as some of us have found out, both cards will play the FM music. Shared IRQs and DMAs are more of a concern.
But yea, FM/388 can be disabled on the AWE64 GOLD!
My YouTube channel
Reply 23 of 33, by retro games 100
I see. If that's the case, then shared IRQs and DMAs can be avoided, by experimenting with different models of SB and clones. BTW, some old games only route their FM to 388. I'm sure you know that! 😉 😀
Reply 24 of 33, by Mau1wurf1977
Oh yea. If you change the FM port, a lot of games will me mute 🤣
A few SETUP.EXE do have an option though...
Reply 25 of 33, by DonutKing
Question... is it possible on the ESS cards to disable the onboard wavetable header, or at least change its volume using a software mixer?
Reason is that I'm trying to figure out how to connect an SC55 and XR385 wavetable daughterboard to my machine. If I connect them both to the same sound card they both play at once. I can always turn off the SC55 but can't do the same for the internal wavetable DB.
Reply 27 of 33, by retro games 100
I have found these attached ESS DOS utils useful. Notice there's an "older" sub folder, for older ESS cards. You can run a DOS util called essvol.exe, and I think you can select the volume level for the DB header. Also, it may be possible to disable the DB header using another util included in this zip file, but I can't remember. Either way, you should be OK with either essvol.exe or esscfg.exe
Reply 28 of 33, by CHiLL72
Thanks, that might come in useful. Anyone looking for a full size ESS1868 card to fit a WB daughterboard, try finding a Terratec Gold 16/96.
Reply 29 of 33, by DonutKing
I dug through my box-o-bits and found an ESS AudioDrive 1869F.
Unfortunately the wavetable header is sort of in the middle of the card, and the card is about an inch shorter than my CT2800.
So basically the daughterboard just hangs there (theres nowhere for its plastic supports to plug into) and it extends below and past the end of the card. It actually extends so far down that the sound card won't fit all the way in the ISA slot.
I suspect that this connector was only added as an afterthought. Were there any daughterboards that were small enough to fit cards like this?
Reply 30 of 33, by retro games 100
Yes. AFAIK, they were "budget" 1 meg things.
Reply 31 of 33, by Tetrium
DonutKing wrote:
I dug through my box-o-bits and found an ESS AudioDrive 1869F. Unfortunately the wavetable header is sort of in the middle of th […]
I've read about this problem before.
Would using a ribbon cable in between the soundcard and the daughterboard be possible?
It would be messy, but atleast you could plug the construct into a board that way 😉
My retro rigs (old topic)
Report spammers here!
Reply 32 of 33, by SquallStrife
Hmm... I have an ESS card... It's older though, ES688. Would that be worth trying out? It wouldn't be for digital or OPL, just the daughterboard.
Reply 33 of 33, by DonutKing
Well I just bought an Acer Magic S20 ISA card, which has a Crystal CS4231A chipset, a wavetable connector and a YMF262 OPL chip. So we'll see how that goes 😀
