First post, by The Khan Artist
I wasn't sure whether to post the bug here or at SourceForge, so if this isn't the right place, just let me know...
I'm using a CD-ROM version that contains both Lemmings and Oh No! More Lemmings. This is tested with both DOSBox 0.58 and CVS 2003 October 06.
The game basically runs fine. It is fully playable, and works at great speeds on my Athlon XP 2100+. I can't get the background music working, but I haven't done much playing around with that yet.
My main problem is the graphics. In the menus and level intro screens, the colors are just fine, but in the levels themselves, the colors are horribly wrong. This happens in both Lemmings games.
I've got Lemmings 95, so here's a comparison:
Lemm95:
Lemmings in DOSBox 0.58 (looks the same in the CVS version):
System Specs:
Motherboard: Asus A7N8X Deluxe (nForce2-based) revision 1.04 w/ 1004 UBER BIOS (nForce Unified Driver v2.45)
CPU: AMD Athlon XP 2100+ (1.73GHz) AIUHB Stepping w/ Thoroughbred-B core @ 2400+ (2000 MHz @ 166 x 12)
Heatsink: ThermalRight SLK-800A
CPU fan: TermalTake Smart Case Fan 2
RAM: Corsair TWINX512-2700LLPT 512MB (2x 256MB Corsair XMS2700-LLPT) Dual Channel DDR333
Video: ATi All-in-Wonder 9700 Pro w/ Omega Catalyst 3.7
Sound: Onboard (nVidia nForce2 MCP-T SoundStorm)
Hard Drive 1: Western Digital WD400 40GB 7200RPM
Hard Drive 2: Maxtor 6Y160P0 160GB 7200RPM 8MB Cache
CD-R/W: Lite-On LTR48246S 48x24x48
DVD-ROM: Matshita SR-8584a 6x/32x
OS: WinXP Pro SP1 Corporate w/ DirectX v9.0b
Reply 2 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
What is your own video mode ?
If you use 256 color mode -> increase to 16 bit.
Water flows down the stream
Reply 3 of 6, by The Khan Artist
I didn't get an option for graphics mode, just machine type. Here's what I used:
My desktop video mode is 32-bit.
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
The problem might be with the CD version.
As normal lemmings (floppy version) runs fine.
Reply 5 of 6, by The Khan Artist
Would you like a copy of the CD version to test with, or should I just go find the floppy version somewhere?
Reply 6 of 6, by Nicht Sehr Gut
Originally posted by The Khan Artist Would you like a copy of the CD version to test with, or should I just go find the floppy version somewhere?
showthread.php?threadid=1080&highlight=Lemmings
