First post, by geoffl
I hope I am posting this in the right place.
Just started using dosbox for an old database program and it works well.
I have the following config.sys file I need to use
device=ansi.sys
fcbs=40,40
buffers=98,8
files=200
stacks=18,512
Can I load this in dosbox?
Any help greatly appreciated
Regards
Geoffl
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Do you NEED those settings, does the program NOT work in dosbox without these? Have you tried?
If you REALLY need those you will have to use a hard drive image and use the dosbox boot command.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by geoffl
program does work - I do not understand why. but I really need ansi.sys.
We program F keys to do specific things
I do not understand hard drive image and boot command
Best regards
Geoffl
Reply 3 of 5, by geoffl
Hi, can anyone tell me how i can load ansi.sys ?
Regards
Geoff
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
You can't, dosbox provides ansi emulation already to a certain level needed by
a bunch of games. For everything else please use disk image support (read upon the
BOOT command in the readme).
Reply 5 of 5, by geoffl
thank you for your help
geoffl
