Master of Magic Memory
First post, by Irmo
Gee, I am so out of configuring DOS
I got Master of Magic to run the intro with VDMS, however, the program stops afterwards complaining about too little memory. Now, I got plenty of RAM, but obviously, it's talkin about the good old 640 kB block. How should I tweak VDMS to get this running?
Thanks
Reply 1 of 5, by Snover
Use DOSBox. 😀
Yes, it’s my fault.
Reply 2 of 5, by Irmo
Snover wrote:
Use DOSBox. 😀
I don't even get that far with DosBox. Can you tell me how to avoid the CD-ROM not found error under DoBoxFro?
Reply 3 of 5, by Snover
Not DoBoxFro. DOSBOX. Don't use the frontend, it's b0rked.
Yes, it’s my fault.
Reply 4 of 5, by Nicht Sehr Gut
Originally posted by Irmo I got Master of Magic to run the intro with VDMS, however, the program stops afterwards complaining about too little memory. Now, I got plenty of RAM, but obviously, it's talkin about the good old 640 kB block. How should I tweak VDMS to get this running?
Presuming it is conventional memory (not EMS) and you can live with the "pause" effect in combat, try turning off features that you aren't using: Joystick emulation, any CD-ROM support (presuming you're running the floppy version), etc...
I think you can also turn off DOSX (DPMI support), that would save about 33k...
Reply 5 of 5, by Irmo
Thanks, I got it working in the meantime using the advice posted by 'swingnchad' at the Master of Magic Resource Center at classicgaming.com (Though I copied the autoexec.nt into the game's directory and changed the program settings to look for it there.) It works pretty well, only movement in combats is somewhat slow.
The url is http://www.classicgaming.com/mom/board/topic. … &topic_id=55134
The post by swingnchad was made 12 July 2003 13:9 PST and is currently the last on that board.
