First post, by joeycape
Hi ppl!
I am on a G4 with mac Os X.2.6, i compiled dosbox and then i typed in the treminal:
cd path/to/the folder/src/where/dosbox/is
./dosbox
and it says:
Exit to error: Can't init SDL Joystick: Couldn't create a HID object iterator.
What did i wrong?
Reply 1 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
You didn't do a thing wrong. SDL reports an error and therefore dosbox exits.
Try running dosbox as "root" to see if that helps.
else remove your joystick
Water flows down the stream
Reply 2 of 10, by joeycape
good idea but nor sudo (admin privilege) nor su (root privilege) has managed to resolve the error.
Maybe did i miss a library or something. Any suggestions?
Reply 3 of 10, by joeycape
c'mon guys, especially mac users, id really love to try dosbox out .
(i really wanna play ascendancy indeed 😁)
Reply 4 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
I don't know
I can think of 3 options
Disconnect any joystick you may have or what can considered a joystick
Secondly get a newer version of sdl (that's the one that's failing here)
Be sure to have in your kernel support for HID
Last option: Edit dosbox/src/gui/sdlmain.cpp and look at line 44.
there is something commented out that may be handy for you.
Reply 5 of 10, by joeycape
ok, thanks for helping anyway...
(at line 44 its written #define DISABLE_JOYSTICK ??)
Reply 6 of 10, by rankin
What revision of SDL are you linking to? The one in fink is horribly out of date and always causes issues. 1.2.6 works, and no longer kills the keyboard if the SDL application doesn't have the full focus. 😉
Reply 7 of 10, by joeycape
I have SDL version 1.2.4...
Should I update to 1.2.6 ?
Reply 8 of 10, by rankin
Yes. 1.2.4 is broken. Horribly so. 1.2.6 should compile 'as is' for the most part 'out of the box' for you. Make sure that you remember wether or not you have X11 installed, and want to support it; --disable-x11 or enable, et al.
1.2.6 should clear up that joystick problem. 😀
Reply 9 of 10, by joeycape
Thanks A lot Rankin !!!! i owe you one!
Its alive , ALIVE 😁
But now i cant install ascendancy....
Shall i open a new topic and bother you w/ it ?
Reply 10 of 10, by rankin
Congrats!
You might want to open a new topic - I've only compiled and written a wrapper for DOSBox in the past - I have no knowledge of that game.
