Configuring Dosbox on Win 7.
First post, by Zachary1234
I am running Windows 7 on a new 64 bit hardware arcitecture.
I can indeed run dosbox, however it has the following issues.
I can't seem to get the -userconf switch to load my dosbox.conf correctly.
I create one using
config -writeconf dosbox.conf
I therefore can't get my default mount script at the bottom of dosbox.conf ro execute.
I find that classic older games, like biomenace, get vertically squashed.
(what setting should I use, once my dosbox.conf loads, to have
the resolution autoscaling work? Is it just the variable included in dosbox.conf?)
Reply 1 of 24, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Reply 2 of 24, by VileR
1) -userconf: post your command line?
2) vertical squashing: setting aspect=true should fix it.
of course, optimal results would depend on your resolution, "output=" setting, and scaler used.
Reply 3 of 24, by Zachary1234
I have the following off a Desktop launch icon's
target text area:
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" -userconf dosbox.conf
The dosbox.conf that I create from the dosbox command line seems
to get written to my Windows 7 Desktop by default.
What do I need to do to run with that conf file?
Reply 5 of 24, by Qbix
Rank DOSBox Author
DOSBox Author
no, use -conf
-userconf doesn't take a parameter. Maybe read in the documentation what it does
Water flows down the stream
Reply 7 of 24, by Zachary1234
I have the following in the target area of my Deskto icon:
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" -userconf C:\Users\Zac\Desktop\dosbox.conf
I have fullscreen=true in dosbox.conf, however dosbox still doesn't seem to read it.
Reply 8 of 24, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Qbix wrote:
no, use -conf
Reply 9 of 24, by Zachary1234
I have used the following in my desktop lanucnher icon:
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" -conf C:\Users\Zac\Desktop\dosbox.conf
and have found that the conf file still isn't being read.
I am using dosbox 0.74.
Any further ideas?
Reply 10 of 24, by collector
Perhaps that is not the correct path to your conf file. Go to your conf file and hold the shift key, right click on the dosbox.conf and choose "Copy as path". The correct path will be on your Windows Clipboard to paste after the -conf parameter.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 11 of 24, by Zachary1234
I can assure you that this is indeed the correct path to my desired conf file,
since it references the desktop, and I can read and see my conf file there!
What ought I do, given my last reply's target commands?
Reply 13 of 24, by Zachary1234
It works just fine on the command line!
What do I do to my Windows 7 Desktop launcher icon to get the same behaviour?
Reply 15 of 24, by Zachary1234
When I try to enclose the entire command as one String,
Windows 7 gives me an error notifier telling me that it just won't accept this.
I then may reply OK, and it will not take the whole command in and save it.
Is there anyone at that end who might know the Windows 7 thing to do?
Reply 16 of 24, by bloodbat
Perhaps try it like this:
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" -conf "C:\Users\Zac\Desktop\dosbox.conf"
That's what copy as path, as Collector suggested, would produce.
Reply 17 of 24, by Zachary1234
I have tried this approach:
and while windows 7 will allow me to OK this on my launcher, dosbox still doesn't seem to execute this at all, and loads without reading dosbox.conf.
Any ideas?
Reply 18 of 24, by bloodbat
Put dosbox.conf where DosBox resides...
Reply 19 of 24, by Zachary1234
I have done so, on Windows 7, with still no success.
It works fine when stipulated from Run, however I need
it to work from a Desktop Application Launcher...
