First post, by nvm
I'm trying to write some dos batch script for manipulating some paths. I haven't done this in years so I might be rusty.
The path is relative and given from the command line as argument
@echo off
set wpath=%1
@echo.%wpath%
set newpath=%wpath:~0,-4%
@echo.%newpath%
The thing I'm trying to accomplish is to get rid of the extension
script.bat whatever/test.txt
whatever/test.txt
whatever/test
But I'm getting
whatever/test.txt
<emptyline>
I'm using DOSBox version 0.74 and this as a reference
Reply 1 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Does that stuff work in real DOS? DOSBox's shell emulates MSDOS 5/6 (and only to some extent), not the Windows Command Shell.
Reply 2 of 5, by nvm
Have no idea, I haven't used anything but linux for the past decade. Works on XP's cmd
Any other suggestion?
Reply 3 of 5, by VileR
well, that reference site calls itself DOS Tips yet says it's "for Windows7, VISTA ,XP, NT, Server 2000, Server 2003, Server 2008".
[cue Family Guy style showtune parody - "the Windows command prompt isn't DOS, isn't DOS, isn't DOS"]
Do you need the extension-less pathname as a variable? or just want to echo it out?
Reply 4 of 5, by ADDiCT
Just use 4DOS, it has a number of advanced string manipulation routines.
Reply 5 of 5, by peterferrie
It works only in the Windows command-shell, because it's relying on an extension that was added in Windows XP.
