First post, by smokingwheels
I have just checked the latest dosbox 0.74 for direct port calls from QuickBasic 4.5 from XP and port H378 did not respond to the out command.
I have a cars ignition system wired to an old Toshiba Laptop 200 MMX runing QuickBasic 4.5 in win98 dos mode. Its been working since 2003 but my I am looking to upgrade to a industrial computer or newer laptop and wondered if Dosbox would support direct port calls eg OUT &H378,0 INP(&H379)
thanks
Reply 2 of 4, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Reply 3 of 4, by smokingwheels
Megabuild I think is for Visual Studio projects, my projects use Quickbasic from 1988
Thanks for comment Dominus
Reply 4 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Megabuild of dosbox (google it). Dosbox itself doesn't have any lpt port support since it doesn't match dosbox gaming only goal. Megabuild does but I'm not 100% sure it would work in that way
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
