dos box completed
First post, by ncmark
I just finished a more "proper" dos box,
1. DTK motherboard with pentium 233 MMX. A little fast for DOS, but more appropriate than the p3 I was using.
2. Seagate ST-6422A drive (6.4 gig). A little big for DOS, but the old 400-Mb conner I was using was too small (and noisy)
3. 64 Gb SDRAM
4.Trident PCi video card
5. A sound blaster vibra 16 ISA card
6. A VERY old AT case - says QMICRO on it - I have a feeling this case dates back to the 486 era.
What do you think? Any comments? 😀
Reply 1 of 19, by Tetrium
Pics of the case! 😁
Anyway, it seems like a well balanced mmx rig 😉
But why did you use the trident PCI graphics card? A Virge would be better I presume
My retro rigs (old topic)
Report spammers here!
Reply 2 of 19, by ncmark
Well, the trident was what I had (shrug).
Same for the sound card - I would have preferred one of the earlier sound blasters (where you actually set jumpers on the card to determine the settings).....
Reply 3 of 19, by Malik
Yes, pics please. 😁
Please wait while your system is being scanned..... ... ........ .. . . . . Done!
- CPU is nice even for the last batch of DOS games (except maybe resource intensive flight sims and driving sims at high-res).
- RAM is in the "very comfortable" region.
- I prefer the S3 Virge or a Trio64V+ PCI card
- I would prefer to have an AWE32 or AWE64 in that system. But SB16 should be ok.
Analysis complete. 😁
Reply 4 of 19, by chinny22
I like big hard drives, you can no-cd your games and save wear and tear on your drive and more important the actual CD's!
Reply 5 of 19, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Why do old PCs always have to be better/best/fastest here, and not what they actually were?
1+1=10
Reply 6 of 19, by bushwack
I had a Trident PCI back in the day, then upgraded to a Virge. And it was good. I still wanted more power though. 🤣
Reply 7 of 19, by ncmark
I found this picture on the internet
http://www.frontier-electronics.co.za/images/old_386dx66.jpg
The case I have is almost indentical; clearly the same manufacturer
This is the board that is in it:
http://www.sk.rs/1998/04/sktd05.html
Ironically, I've had that computer a long time, but it never saw much use. I quickly moved on to a p3//500, and this one just sat there.
Reply 8 of 19, by bushwack
That's a pretty sweet case.
Reply 9 of 19, by ncmark
Yeah, those old cases were built like tanks 😁
Reply 10 of 19, by Malik
Yep, nice case! And my favourite Turbo button and the LED are there too! 😀
And about the HDD size, for pure (Dos 6+FAT16) DOS, any HDD size upto 8GB is fine. I usually allot the frst 8GB fot DOS in a multi-OS HDD.
Reply 11 of 19, by ncmark
I am not sure I agree on the hard drive - anything over 2-gig and you have to start partitioning, which I don't really like. But it's okay.
Like the motherboard, the hard drive never really saw much use either. It very quickly became too small for wn85/98, and has been sitting around for a long time.
One thing is true about those old cases - you don't have vibrating or rattling panels!
Reply 13 of 19, by Malik
Yeah, 8GB is the max (assuming the IDE controller supporting it) you can go for with Dos6+ in the FAT16 partition.
I always have these partitioned to 2GB+2+GB... The first I label the volume as MS-DOS_622, which contains all the operating system files, loaded drivers' directories, installed dos and win3.x applications,etc.
The next, I label as FILES where I put all the installation files for applications of both Dos and Windows 3.x. The next partition, I label the volume as GAMES, where I install the games to, and another partition labeled MIDI or sometimes MUSIC for music stuff. The final partition I usually reserve as BACKUP or SIERRA.
Reply 14 of 19, by Tetrium
That's kinda exactly how I partition my drives! 😳
Partition 1 is always just the OS (+ whatever junk I put on the desktop 😜 )
Partition 2 is just programs
Partition 3 is games
Partition 4 is data, where I also put all my downloaded stuff
And depending on the size of the harddrive I use fewer partitions
Reply 15 of 19, by ncmark
well I haven't put win 3.1 on it (yet) - if I do it will likely be on another partition
I used to have a conner 1275 Mb drive that was in a 486 box, and that was about right for DOS, but it eventually died.
(The seagate is a LOT faster anyway) 😁
Reply 16 of 19, by sebaz_ri
ncmark wrote:
64 Gb SDRAM
Whew! 64gb of SDRAM, i never knew they existed, wish i had one for my P-III 1Ghz
Reply 17 of 19, by mr_bigmouth_502
sebaz_ri wrote:
ncmark wrote:
64 Gb SDRAM
Dang, you beat me to the punch! 🤣
Reply 18 of 19, by leileilol
sebaz_ri wrote:
ncmark wrote:
64 Gb SDRAM
Gotta have it for those 1999 Krystal engine dos games like shoot alien 3
Reply 19 of 19, by ncmark
okay, okay 64 MB
I never said I was a good typist
