Slow Performance in MM2
First post, by coppercitymt
Hello everyone, I am having some problems with my PC (below) and Midtown Madness 2, It meets the system requirements. It's bearable with the city bus, but when I drive the faster cars it can't keep up, it gets jerky. I don't think it's using the Voodoo card, it's set on hardware 3d at 640X480 Med and Low settings. I don't get the 3DFX screen flash when starting the game.
Any ideals?
Reply 1 of 3, by Markk
Try to disconnect the passthrough cable while playing. If the screen is blank then, it surely isn't using the voodoo card.
Reply 2 of 3, by tgod
If its not using the Voodoo 2, I would think you would be able to switch to it with the "Display" option?
Reply 3 of 3, by coppercitymt
I doubled the ram from 64 to 128, and installed a 466 CPU vs a 366 CPU, It's working fine I can fly around at 100Mph, with only the slightest jerk.
