First post, by Sgt. Nukem
Hi there!
I'm from Germany and therefore got a different keyboard layout.
The problem lies at the backslash ( \ ). Usually we use "ALT GR" + "ß ? \" (exactly next to zero). But this combination doesn't work in DOSBox! 😒
Since it is impossible to paste some paths into DOSBox, I can't mount any drive and so DOSBox is completely useless to me.
Waaaaaahhhh!! I wanted to play "Ultima VIII : Pagan" again...! Help me and the Avatar to rescue earth! 😉
Reply 1 of 4, by Freddo
I live in Sweden and have the very same problem. I can't write \ in Dosbox.
I bypass this problem by putting the game directory directly in the folder where I installed Dosbox. If I have C:\Dosbox I made a C:\Dosbox\game, for example. Then I type "mount c game" in Dosbox.
Reply 2 of 4, by Silent Bob
You can use "/" instead of "\", or mount the directory in "dosbox.conf".
Reply 3 of 4, by Guest
or, even better to me, use "boxer"! (can't recall where i got it but google should help!)
