First post, by ScreenGems98
Help! now whenever I try to install Windows 95, MS-DOS, or anything, it will never start correctly. I will try to boot it, and it only says "Booting from drive A. . .", and just stays like that. Someone please help!
(P. S., I don't want to use VirtualBox and Virtual PC because I want to make it portable, and they aren't portable, OK?!?!?!)
Alexander
Reply 2 of 8, by Jorpho
http://www.lmgtfy.com/?q=virtualbox+portable
Reply 3 of 8, by ScreenGems98
I try to download it onto my usb but it never runs
Alexander
Reply 4 of 8, by ScreenGems98
Both VirtualBox and Virtual PC show up with errors. They just won't run. Though, DOSBox runs correctly from USB. And Dominous, I always see you talk about it, but of course now you are saying it isn't supported.
Alexander
Reply 5 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I would love to see Windows 95 to be supported but it just isn't. Please fix your posting and hit reply, not akways making a new topoc.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 8, by fillosaurus
:@ScreenGems98
YOU ARE ANNOYING! Learn how to post properly, do not open a new topic every time.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 7 of 8, by eL_PuSHeR
[Related topics merged]
Reply 8 of 8, by Jorpho
If you are not using the version from http://www.vbox.me/ , that's probably quite likely.
Whatever problems you are having with portable VirtualBox are probably minor in comparison to the problems you will experience in trying to install Windows 95 in DOSBox.
