First post, by codingnoob
hi,
(i'm running win 8 pro 64bit)
i'm trying to run starfleet 1 but that game has a problem with the official dosbox build .74.
Star Fleet I - File Read Error
so i downloaded the latest vanilla SVN 3820 but it is simply a 7zip archive. in the dosbox svn guide http://www.dosbox.com/wiki/SVN_Builds#How_do_I_use_it.3F , it says that i should just copy over the files of the official install with the files from the archive which i did.
however, dosbox still does not know where to find libpng13.dll and i suspect it will not be able to find zlib1.dll either.
am i supposed to copy those files manually somewhere or should i get an installer that i'm not aware of?
and if i'm supposed to manually copy the files somewhere, can you please specify where (system32? syswow64? etc.) and if i need to copy it to multiple locations. i'm reluctant to screw around in my system directories if i don't have to.
thank you much.
