First post, by wallstreetobserver
Running XP SP3. LEWP runs in XP, but not well. That is why I want to use DOSBox, but it will not run in DOSBox. When the program gets past the welcome screen it hangs as it tries to load the printer driver.
This is the same behavior it had when I would try to run it in 98se after booting directly into DOS. It ran fine in 98se when booted normally. I'm guessing that LEWP can't read the large hard drive in a full DOS mode.
Any help on configuring DOS Box would be appreciated.
