Problem with 2.1.0
First post, by Kahenraz
When I installed 2.1.0 everything was great. When I loaded dosdrv, vesa mode automatically turned on (which is what I want), but after I accidentally hit "Run with VDM" (with the musical note) on it after right clicking an icon, everything seemed to switch back to 2.0.4. Meaning, vesa did not auto-load. This was the problem I had with 2.0.4, there is nowhere to specify upon typing dosdrv to load the vesa drivers or cd-rom emulation. I need this because I cannot mix mouse2kv and a custom configured vdm 2.0.4 file.
Is there a way to specify vesa and cd-rom emulation to start in the ini file?
Reply 1 of 1, by Snover
That doesn't really have anything to do with 2.1.0... and it wasn't switching back to 2.0.4... it just wasn't reading the VLP file and run with VESA is disabled by default. All it does anyway is force the DOS box into fullscreen anyway -- which you can do by hitting Alt+Enter.
Yes, it’s my fault.
