OpenGL scaling in DOSBox
First post, by romek41
Hello there!
When running DOSBox in fullscreen mode, I can often notice black borders on the screen - i. e. when using resolution 640x400 in emulated PC and 640x480 in my real computer, DOSBox displays 40 black lines over and 40 black lines under the picture, instead of stretching the picture to full screen. I have decided to correct this, using OpenGL for display. The result of my work (modified sdlmain.cpp from DOSBox 0.60 - if you want to compile DOSBox with it, then you must also link executable with OpenGL, '-lGL' on Linux) is in the attachment. But there are some problems with this code:
1. It does not work with threaded video display (segfaults - I do not know why).
2. It displays a white, one pixel wide border around the display when switched to fullscreen.
Does anyone know how to fix them? I am newbie on OpenGL, so I would be very grateful for help...
Also note, that:
1. In actual stage it shows fullscreen display at 1024x768 resolution (I'm going to change this behaviour in the near future).
2. It will be really slow if you run it under plain Mesa, or Micro$oft software OpenGL. To achieve reasonable performance you will need 3D accelerator with hardware OpenGL support.
3. It won't work at all, if your OpenGL cannot use large textures.
That's it for now. I hope I will find enough time to complete this code...
Reply 2 of 12, by Harekiet
Rank DOSBox Author
DOSBox Author
Oh well already working on opengl support, and with that a little change in vga update code, since i'll remove the multithreaded display updates, sorry for multicpu users 😜
Texture upload speeds in opengl are quite horrible though, using an nvidia extension helps it alot, but for non-nvidia people they'd better use the overlay support i think.
Reply 3 of 12, by Darkfalz
Most cards support RGB overlays, don't know why you're using YUV overlays.
What about plain old hardware stretch?
Reply 4 of 12, by Harekiet
Rank DOSBox Author
DOSBox Author
Not supported by sdl.
Reply 5 of 12, by Darkfalz
Is Direct3D supported by SDL?
Reply 6 of 12, by Harekiet
Rank DOSBox Author
DOSBox Author
Not much use for Direct3D in a cross-platform multimedia library 😀
Reply 7 of 12, by robertmo
heh - so I understand now why colours are so strange when I set "overlay=truth" 😀
Reply 8 of 12, by oneirotekt
Curious, has anyone run current versions of DOSBox much on a multi CPU system? How much does performance improve? Can you get twice the cycles out of it compared to a comparable single CPU system, or is it somewhat less than 2x?
Reply 9 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
far less:)
Graphics is one thread. CPU emulation is the other.
See a bit like running with frameskip=10 😀
Water flows down the stream
Reply 10 of 12, by quasarstrider
How about using ARB_pbuffer and ARB_render_texture, at least on the cards which support the extensions?
Reply 11 of 12, by Harekiet
Rank DOSBox Author
DOSBox Author
ARB_pbuffer and ARB_render_texture don't help with texture upload speeds which is the main opengl bottleneck, the nvidia extensions allows you to do agp dma transfers, but as far as i know they are discussing and ARB_* version of it too, so we'll have to see if that ever gets added. They already added the nvidia vertex_buffer so who knows 😀
Reply 12 of 12, by Srecko
OpenGL is really slow on my radeon, but overlay is quite fast and works without problems (only picture is a little blurry), including scaling.
I guess agp 8x interface improves performance here (unlike 3d games which rely on graphic card's internal memory speed which is a lot better than AGP's).
There probably shoudn't be much difference between overlay and opengl in speed.
