Why pkzip.exe so slow ?
First post, by HeMason
I'm programming a dos ap in dosbox 0.74. I try to access some files, but it seams very slow ?
As I tracing into dosbox.cpp, and try to figure out :
How dose Normal_Loop() work ?
How dose "ticksxxxxxx" variables mean ?
How dose "CPU_xxxxxx" variables work (in cpu.cpp) ?
They must be under a cursed !
Can anyone give me a hint? or uncurse it, please!
Reply 1 of 14, by HeMason
when I use pkzip.exe in dosbox, it's very very slow. Why?
Reply 3 of 14, by HeMason
Wow~ It works! thk's very mush.
I am so curious, where hide the "cycles" command ?
Reply 5 of 14, by HeMason
I see.
But when I set [cpu/cycles = max], nothing happen? It still slow.
Another question:
I have a custom's dos ap writen by clipper. If I set [cpu/core = auto], it can't be run. But when I set to "simple", It works !
But others dos ap (writen by clipper also) can run
properly, whatever I set to "auto" or "simple".
Why?
Reply 6 of 14, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
[cpu/cycles = max]
depends on where you have written what EXACTLY. Hard to say from what you wrote.
As for core, some programs are picky and can'T run otherwise. for the picky ones, write a batch file called "run.bat" and put core simple in one line and the exe/com of the program in the next one. instead of running the exe you then run the run.bat.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 14, by HeMason
That's I wrote:
[cpu]
core=auto
cycles=max
something wrong?
In DOS non-gamming ap, if I just set core to "simple", what will happan ?
Reply 8 of 14, by HeMason
Besides "cycles=max", is there any method can speed-up more ?
In one case, I reindex all the database. It spends 6 mins. But in real DOS, it just 1 mins !
Reply 9 of 14, by leileilol
core=dynamic
Reply 10 of 14, by Joey_sw
Disclaimer: dbase, clipper, foxbase program are not supported by dosbox
-fffuuu
Reply 11 of 14, by HeMason
leileilol wrote:
core=dynamic
yes! yes! Look like turbo speed.
Thank's a lot.
Reply 12 of 14, by HeMason
Why !
Did you find something wrong ?
Reply 13 of 14, by R153nm
The general rule of thumb around these parts is the developers of Dosbox built it specifically for games. Many application specific features (Share.exe, printing, parallel port access, etc.) are not implemented because no game needs them, thus applications are considered unsupported.
Reply 14 of 14, by HeMason
Thank's for your explanation.
I solved the printing problem in 2004. And there was no need to access com port. The product in Taiwan is called HyperDos. But it can't run in 64-bits OS. So I thansfer the cmd.exe(ntvdm) to dosbox . It seems work well.
There were almost 10k users in Taiwan. And HyperDos is the only one solution.
The URL is:
http://www.stone.com.tw/stone/product/showpro … jsp?did=13&m2=0
