What Voodoo?
First post, by kixs
What do you guys recommend... I currently use Voodoo3 AGP and PCI versions - AGP on P-3 833 and PCI on P-1 233MMX.
I was thinking on getting a Voodoo2 or maybe Voodoo Banshee.
What is more compatible with glide titles: V2 8MB, V2 8MB SLI, V2 12MB, V2 12MB SLI, Banshee 16MB? Can someone rate these combos?
I just want to have a fully working and compatible setup and I'm not sure if V2 12MB SLI is over the top if V2 8MB SLI does the job.
thanks
Reply 1 of 7, by leileilol
Going from Voodoo3 to Voodoo Banshee is pointless since Voodoo3 is practically a dolled up Banshee.
A single Voodoo2 12MB was enough for me. Use it in addition to your Voodoo3 so you attain higher DOS Glide compatibility while keeping your powerful host Voodoo3 card for the Windows Glide games.
FUCK "AI"
Reply 2 of 7, by Unknown_K
If you are going to mess with a V2 get 2 x 12MB (same brand) for SLI and pair them with a nice AGP TNT card, should run everything well.
All the early 2d+ 3d 3dfx cards before the V3 were bombs and had issues (cut down 3d hardware to make everything fit, bad drivers). I collect them just to have them.
Reply 3 of 7, by kixs
So Banshee is not an option... also 8MB V2 is no good even in SLI. I'll try to find some V2 12MB.
Thx
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 4 of 7, by Putas
If you don't have a game that would reject V3 then there is no need for older cards.
Reply 6 of 7, by elfuego
Amen 😊
Maybe even TNT2 (pro).
Reply 7 of 7, by vetz
If you don't gonna play any of the games in the matrix linked above (or Mechwarrior 2: 3DFX edition) then there is no point switching to Voodoo2. If you are planning on doing it, then Voodoo 2 in SLI should give about the same performance as a Voodoo3. Remember that you are using a P233, so you won't see much difference between 8MB SLI and 12MB SLI.
