First post, by bristlehog
- Oldbie
I am trying to install a 4 Gb CF card into a 486. First inserted it into a P3 system with HDD parameters autodetect. It works perfectly, and here are the parameters:
Cylinders: 977
Head: 128
Sector: 63
CHS Capacity: 4033 Mb
LBA Capacity: 4034 Mb
I created a primary DOS partition (2 Gb) on it and did a format /s. It boots at a P3 system, but at 486 it won't! Because 486's Phoenix BIOS only accepts a two-digit number of HDD heads, thus I can't provide the correct number. If I set a different number of heads, the 486 won't read the card, saying 'Sector not found reading drive C:'
How do I cope with it?
Hardware comparisons and game system requirements: https://technical.city
