Reply 80 of 93, by TELVM
- Oldbie
Never fiddled with those Zalmans but the reviews say they fit s478:
Let the air flow!
Let the air flow!
Yea also can't find 478 mentioned: http://www.zalman.com/global/product/Product_ … ead.php?Idx=277
Hum ... I think what probably happens is that for the 9500A selling nowadays (2013) they've discarded the much in disuse s478 gear. I'd look then for a second hand ~2007 vintage one. Or buy a new one and McGiver the mount 😎 .
Let the air flow!
wrote:Hum ... I think what probably happens is that for the 9500A selling nowadays (2013) they've discarded the much in disuse s478 gear. I'd look then for a second hand ~2007 vintage one. Or buy a new one and McGiver the mount 😎 .
yea, the original came out in the late s478/462 era. As for the P4 version, all you need is an aluminum bar between the posts on the stock plastic mounting posts. I can provide pictures if need be. As for S464/A you need the 4 mounting holes on the motherboard and zalman's adapters. These adapters will let you put just about any heatsink onto 478/462.
Researching into P4 gear and found this in the manual from a Zalman cooler: http://www.zalman.com/global/product/Product_ … ead.php?Idx=152
I'm using a Zalman CNPS7000B-Cu on a 478 Prescott 3.2, it stays in low 60's under full load, idles in low 40's @ 20c room temperature, but does have one down side, dust collection, it's a really efficient vacuum cleaner!! See pic!
Overclocking is not an option on this crappy board, Asus P4R-800-VM ATi IGP chipset), nothing in BIOS whatsoever, it's also a picky git about RAM, and with only 2 slots this a pain. So for now only 512mb.
wrote:I'm using a Zalman CNPS7000B-Cu on a 478 Prescott 3.2, it stays in low 60's under full load, idles in low 40's @ 20c room temperature, but does have one down side, dust collection, it's a really efficient vacuum cleaner!! See pic!
I have almost the same exact cooler, sale page said it worked on 478, when I got it box said otherwise. I wound up using it on some phenoms instead.
I wonder what the temps would have been if they hadn't goofed up and polished the base.
wrote:^ That Scythe Mine is a great relic, love the flat polished copper base. […]
Manages to keep 125W at bay @ Δ20C with just one 100mm fan. Preshott tamer
has any one tried the Scythe Shuriken Rev.B Quiet yet?
any mounted a zalman 9500? if so how?
No found it too hard / expensive to source one.
But I have this one on it's way to me:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewI … d=1164298932008
I'll let you know how it performs...
what do you guys think of the XP-90 performance wise? have one of these at work.
http://www.silentpcreview.com/article194-page1.html
http://www.newegg.com/Product/Product.aspx?It … N82E16835109119
the cool thing is it fits 478 and AMD and it just so happens i'm set to replace my p4 board with an AM2 board soon.
wrote:what do you guys think of the XP-90 performance wise? have one of these at work. […]
Very good but sadly missed out and it like all the rest of the really good 478 coolers it is hard to find. Don't want to bother with the CNPS7000/7700 series coolers although I used to have a bunch of them.
well if you live in the states you get a few for cheap.
http://www.ebay.com/itm/Thermalright-XP-90-LG … =item3f33270667
How about this one (USA) ?:
http://www.ebay.com/itm/261473266622
Brand new($29.99/bestoffer), which hopefully would mean the s478 adapter is included.
http://www.xbitlabs.com/articles/coolers/prin … the-ninja2.html
Europe(some also worldwide):
http://www.ebay.com/itm/231224859810
or
http://www.ebay.com/itm/281317851763
or
http://www.ebay.co.uk/itm/141220215810
or
http://www.ebay.com/itm/111347790058
...various pricing, and for the used ones one should probably ask if the correct adapter is present.
(all Scythe models - Mine/Mugen/Ninja, if the links disappear...)
