nforce4max wrote:I have messed with two 805s and they nearly ruined a board 🤣 (overclocking) and yes they are faster. Try the 9xx series as they are closer to c2d performance than the 8xx.
I am finally done with the Pentium D 8xx testing.
No motherboards were destroyed benchmarking these CPUs
The Pentium D 9xx CPUs will be next.
I tested 3 Pentium D 8xx CPUs
Pentium D 805 20*133 = 2666 mhz ~Price late 2005 $163
Pentium D 820 14*200 = 2800 mhz ~Price summer 2005 $241
Pentium D 840 16*200 = 3200 mhz ~Price summer 2005 $530
I tested the 805 and the 820 @ 3800 mhz because it makes it easy to compare their performace against a single core Pentium 4 570 3.8 ghz.
The 805 was tested with low fsb and decent memory speed and the 820 tested with high fsb and low memory speed so it is also intresting to see how these two low end dual core CPUs compare against each other.
I will not post screenshots for all test results with these two Pentium D CPUs and the P4 570 @ 3.8. It would just be too many screenshots to upload.
Feel free to request a screenshot for any benchmark if you feel something smells fishy 😁
Platform: i975X, Memory: 2x1gb ddr2, Video card: Geforce 7900 GTX.
All tests were run with these settings.
Pentium 4 570, 3.8 ghz 1.35v, 19*200, memory speed 301 mhz 3 3 3 8
Pentium D 805, 3.8 ghz 1.45v, 20*190, memory speed 317 mhz 3 3 3 8
Pentium D 820, 3.8 ghz 1.45v, 14*271, memory speed 271 mhz 3 3 3 6
SuperPi 1m
Identical scores! All three CPUs finished the 1m test in 34 seconds.
3dmark 2001
The 820 scored the best result with 28659 points
In second place we find the 805 with 28024 points
The P4 570 scored a bit lower than the dual cores with 25956 points
3dmark 2001 as shown in earlier tests prefer high FSB over high memory speed.
3dmark 2001 does also benefit from dual core CPUs but there isnt a huge difference in scores.
3dmark 2003
The 820 scored highest with 22482 points
In second place we find the 805 with 22388 points
In last place we wind the P4 570 with 21495 points
3dmark 2003 dosnt care much about fsb or memory speed so its not a huge surprise that the two dual core CPUs score almost equal.
3dmark 2003 will be GPU limited what ever we do but it seems to prefer dual core CPUs over Single Core CPUs.
3dmark 2005
The 820 scored highest with 9930 points
In second place we find the 805 with 9813 points
The P4 570 with 8560 points is last.. again...
I think we are starting to see a trend.
3dmark 2006
The 820 scored highest with 6058 points
In second place we find the 805 with 6047 points
In la... third place The P4 570 with 5259 points
The newer the benchmark the more the dual core CPUs advantage over the single core CPU grows.
PCmark 2005
1: 820. PCmark score 6602 points. CPU: 6311, Memory: 4938, Graphics: 8938, HDD: 6606
2: 805. PCmark score 6490 points. CPU: 6252, Memory: 4419, Graphics: 8724, HDD: 6597
3: 570. PCmark score 5382 points. CPU: 4861, Memory: 4554, Graphics: 8725, HDD: 6640
The 820 wins the memory test by a large margin although it has the slowest memory. Again we see the importance of FSB.
The Pentium 4 570 wins the hdd test and get the about the same graphics and memory scores as the 805 but it is dead last in the CPU test.
SiSoft Sandra 2011 CPU Artihmetic and Multimedia
The Pentium D 820 (red) scores equal to the Pentium D 805 (Orange) and the Pentium 4 570 (green) simply suck.
SiSoft Sandra 2011 Memory speed and latency
In these two graphs the 820 is red, the 570 is orange and the 805 is green (notice that the 805 and 570 have switched color).
Here we again can see that memory speed in mhz dosnt give much benefit if the FSB is too low.
To sum it up.
Dual core is better than single core and memory speed gives little benefit if the front side bus is to low to make use of the memory speed.
I will post the results for the Pentium D 840 @ 4000 mhz in a separate post.
