First post, by silsor
The listing for this game is here. The game may be downloaded here.
I have tested this game with dosbox 0.61 and the current CVS.
Screen after running the game:
This is just a message printed by the DIGPAK sound drivers. I have it configured not to use any sound at all, but I have tested it with a bunch of drivers, and with sound emulation disabled.
At this point, if I press a key, dosbox does one of the following:
  • returns to the DOS prompt, no messages in the debug log, I cannot type at the DOS prompt, dosbox still responds to function key commands
  • returns to the DOS prompt, but dosbox spams an infinite number of "CPU: Illegal Unhandled Interrupt Called 6" in the debug log, OR "CPU: Illegal Unhandled Interrupt Called 5". When this happens I cannot type at the DOS prompt.
  • exits with the message "Exit to error: CPU:GRP5:Illegal Call 7" in the debug log
  • crashes with
    IO:WriteW:Out or range write A4 to port 6030
    Fatal signal: Segmentation Fault (SDL Parachute Deployed)
  • crashes with
    IO:WriteW:Out or range write 6 to port C61E
This game is an ancient port to PC of an Amiga game so I expect it to be a little wonky; it never even ran very well under DOS.
Reply 1 of 14, by MiniMax
Rank Moderator
Moderator
I needed to test one DBFrontend with a game, so I downloaded Tower of Souls, and tried to run it. I can confirm what silsor writes. No matter what type of sound driver is chosen during SETUP, the TOWER game proper always complains about a wrong or missing BLASTER variable.
I even tried disabling the Sound Blaster emulation in DOSBox, and added a "SET BLASTER=A220 I7 D1 T4" to the AUTOEXEC section, just as the game suggested, but it still refused to run.
I will try it with VDMSound later...
MiniMax
_________________
Reply 2 of 14, by Harekiet
Rank DOSBox Author
DOSBox Author
Very strange, game might try to do some strange way of accessing the environment variables i'd guess..
Reply 3 of 14, by MiniMax
Rank Moderator
Moderator
That game is strange! I tried to run it in pure DOS (configured for no sound) and it just hang! Had to do a hard reset to get the system back.
Tried to run it with VDMSound, and the same error about a wrong/missing BLASTER variable.
silsor, if you really want to play that game, perhaps finding an Amiga emulator and the original Amiga version might work better?
MiniMax
_________________
Reply 4 of 14, by Stiletto
Programs with problems like this are the best to try and debug DOSBox. Have fun, Harekiet and Qbix!
do the Fandango!" - Queen
Stiletto
Reply 5 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
thanks Stiletto 😉
Maybe it's for you a nice way to increase your dosbox debug skills as well 😉
Water flows down the stream
Reply 6 of 14, by Stiletto
Qbix wrote:
thanks Stiletto 😉
What - from nothing? 😉
Sorry Peter, I don't have the time!!!
Stiletto
Reply 7 of 14, by robertmo
heh - this game just needs to have autoexec.bat on c:\ with set blaster somewhere (it can be remmed) 😉
Reply 8 of 14, by robertmo
I just thought some games may use same method for detecting files=
Reply 9 of 14, by MiniMax
Rank Moderator
Moderator
Urgh!! That is ugly 😈 Will try it this afternoon, if noone else beats me to it.
MiniMax
_________________
Reply 10 of 14, by silsor
That's right, this is the pathological case ;)
Reply 11 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
weird though It should look for the bootdrive and look there for autoexec.bat
Reply 12 of 14, by eL_PuSHeR
I tried it yesterday and i am getting same errors as everyone else reported on this thread. What a lousy programming. 😠
Reply 13 of 14, by MiniMax
Rank Moderator
Moderator
FWIW, I added a SET BLASTER=A220 I7 D1 T4 to a dummy AUTOEXEC.BAT in my DOSBox C: driver, and Tower of Souls started allright.
Something is wrong with the opening graphics though... After a short delay it displays a nice looking "PRESENTS..." in large yellow letters on a blue background (see snap 1). I would have expected this screen to be preceeded by a the name of company producing the game?
Next something weird happens to the palette (snap 2 and 3) before the intro runs, and the magic pen starts writing on the scroll, at which time everything looks fine.
I also tried running ToS in pure DOS with a dummy SET BLASTER in my AUTOEXEC.BAT, but it still completely locked up my PC. So DOSBox is a better DOS than MS-DOS 😁
The same happened when I tried it with VDMSound.
MiniMax
_________________
Reply 14 of 14, by MiniMax
Rank Moderator
Moderator
Tried it with ripas CVS build dated March 7, 2004 - same problems with the palette.
MiniMax
_________________
