Alien Breed (1993) DOS
First post, by Fexel
I can play the Game, but without Sound, cause of the deactivated XMS Support in my Config. If reactivate the XMS Support the Game starts but i cant check the Copyprotection Code. Any Idea?
Some additional Informations:
I tried SVN Daum Version, DOSBox 073,072 and 074.
Reply 2 of 3, by Fexel
If the XMS is deactivated, i can enter the copy-protection code, hit enter and play the game - but without sound.
If I activate the XMS i can also start the Game and i can enter the copy-protection code but i cant play the game cause there comes no reaction if i hit the enter key.
Reply 3 of 3, by gaffa2002
I ran into same issue and the root cause was the system having too much RAM, so setting Dosbox to map only 16mb may help.More information may be found here:
Re: SBPCI128 no sound with Cannon Fodder and Alien Breed
LO-RES, HI-FUN
My DOS/ Win98 PC specs
EP-7KXA Motherboard
Athlon Thunderbird 750mhz
256Mb PC100 RAM
Geforce 4 MX440 64MB AGP (128 bit)
Sound Blaster AWE 64 CT4500 (ISA)
32GB HDD
