First post, by Nic-93
I have downloaded the latest version of munt, and when it goes to scanning audio devices, it just stays there and dont proced to the main menu interface.
its 64-bit windows im on, windows 8.
Are you talking about the Munt driver or the QT app? If you are talking about the special build of DOSBox with Munt, keep in mind that it is not an official build that is supported here. If it is a problem with Munt itself, you should ask in the Munt forum where the Munt developer will see it.
im talking about the external windows 32-bit app, it worked fine in previus versions.
and were is the forum?
Moved to the correct forum
wrote:Moved to the correct forum
thanks, i couldnt really find it.
