Munt mt-32 emulation gets stuck. (( Closed ))
Reply 20 of 32, by sergm
Alternatively, you may simply use a DOSBox with MT-32 emu patch and don't bother with the app, if it is what you really need.
Reply 21 of 32, by Nic-93
sergm wrote:
Exactly.
hmmm, the only way i honestly can get mt-32 emulation are in the app.
Reply 22 of 32, by sergm
That's also weird... So, you're saying, even the MIDI driver doesn't work on your system?
Reply 23 of 32, by Nic-93
yep..im that much out of luck with getting mt-32 working,
Reply 24 of 32, by sergm
Agree...
Reply 25 of 32, by Nic-93
Unless you can get a work around it.
Reply 26 of 32, by sergm
I don't realize what could possibly happen that there would be no way to run a DOSBox binary patched with mt32emu 😒
Reply 27 of 32, by Nic-93
Well, im one of those odd users.
Reply 28 of 32, by sergm
Too bad 🙁 I can't fix things not knowing what those are...
Reply 29 of 32, by Nic-93
like i said, its not moveing on from scanning for audio devices, and it stays there.
Reply 30 of 32, by sergm
Like I said, it's irreproducible to me. You need to debug it.
Reply 31 of 32, by Nic-93
hm, well, i cant find the source at all.
Reply 32 of 32, by Nic-93
This thread can just be closed, ive removed it.
