First post, by comteck123
Hi, I would like to ask if how would I play Daggerfall in DOSBox with GUS enabled? You see, It does work with Digitized sound but with Music It doesn't. It just says: Error could not initialize MIDI Driver. Well I already setup the ULTRADIR, and stuff like that so even with that it doesn't work. But when I use loadpats it works, only problem is that for example: When I enter a building and get out it just loops the one part of the music and freezes that specific sound. Which is annoying. So yeah is there any other way?
The Shadow Warrior Mod that makes weapons O.P., plus adds more ammo: My First Shadow Warrior mod.
