First post, by Borg Number One
DOSBOX memdump feature is great, but it is not really easy to convert the [HEX] memdump.txt to [bin] memdump.bin every time.
To convert the HEX-data to bin-data I have to start "open office" and use its "find and replace"-feature to remove the offsets.
Then I have to copy the "HEX"-Text into hexworkshop while "interpret as hexadecimal string" is switched on.
Please insert a feature which makes it possible to dump memory as bin-data to a file too.
e.g.:
memdump 000000:000000 100000 ->"normal way"->memdump.txt
memdump 000000:000000 100000 -b ->"binary way"->memdump.bin
