Reply 20 of 47, by ripsaw8080
- DOSBox Author
It's possible there is no way to revert to the internal BIOS font once a codepage font is loaded, at least not in the same session; but it doesn't seem like something a person would typically need to do, and it's easy enough to restart DOSBox.
wrote:I will gladly include a CGA True Type font in the project if I get one... do you know or have any?
No, but I've made a fairly comprehensive set of IBM fonts in Windows raster format. Raster fonts are so much easier to work with than TrueType when trying to reproduce DOS bitmap fonts.
wrote:As for being aware of the 40-column mode, yes, I am... actually, having ported the game from 83' 16-bit DOS to 2015 32/64-bit POSIX, I've *had* to be aware of that and all other platform-dependent things in Rogue, including the many assembly files, which I "translated" to C and documented as best as I could. I'm also trying to preserve all modes such as the DEMO mode and the "Software Pirate killed by the Copy Protection Mafia", as well as true underline for mode 7.
I'm not aware of a demo mode, is it a feature of Epyx Rogue? I'm more familiar with the original AI Design versions. Yes, the "crack attempt detected" mode of Rogue is hilarious not just for the epitaph, but also the hindrances during gameplay, like invisible monsters. 😀
