First post, by Kalistan
Is the HQ2X in the 20th CVS build (I thought I heard it was going to be). If it is, what are the parameters to implement it (as i am sort of a newbie and use Dfend for about everything 😁 ). If it's not in this last build, I hope you don't mind my asking when it will be included. As always, I am amazed at how sweet dosbox is (once you get a taste, it increases the appetite...i feel sorry for you coders, 🤣.) You know that your users have track marks all over their arms, and their tolerance builds with each build, although you are much more altruistic then drug pushers, so i apologize for the analogy.
