First post, by Beegle
- Member
I recently received an adapter that converts SD cards and passes them as IDE hard drives to the host motherboard.
Attached picture is my model.
I was able to detect it as a primary hard disk, format it, and install MS-DOS 6.22 on it.
However when comes time to boot from the SD/IDE hard disk, it just stalls for a long time, then spits the well-known 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'.
I'm wondering if there's some manipulation I have to do, either on the SD card, or in the BIOS, to allow booting from this device. Is there even a boot record/sector on SD cards?
Worth mentioning is that the DOS installation returned no errors and seemingly no incompatibilities.
When opened on my main PC on Windows 7, the SD card reports being formatted in FAT (which seems appropriate). File structure seems also normal for a clean DOS install.
Here's what I tried
0. Reinstalling a few times from different MS-DOS disks. No difference. Installing on a real hard drive works perfectly and creates a working bootable disk.
1. Changing the IDE connector from the middle to the end plug on the IDE cable and back. Still gets recognized on the Master channel no matter what.
2. Letting the disk be auto-detected on the fly. Or auto-detected in the BIOS options. Or setting values manually. This changes how the computer perceives the simulated disk (sometimes as LBA, sometimes as CHS, sometimes as LARGE, with varying sizes) but does not prevent the infinite freeze and/or DISK BOOT FAILURE message.
Any ideas on some obvious things I might have missed?
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
