First post, by superfury
I'm using the Generic Turbo XT BIOS v2.5 with an ATA-1 controller and PCI mapping in my emulator. Anyone knows a IDE BIOS that will work with the ATA-1 hard disk controller? The XT-IDE Universal BIOS doesn't seem to work (it executes some non-ATA-1 commands and hangs trying to execute one of them.
UniPCemu Git repository
Reply 1 of 16, by superfury
I've managed to get the Western Digital IDE SuperBIOS v2.0 implemented in the Super PC/Turbo XT BIOS for Intel 8088 or NEC "V20" Motherboards. It now gives my ATA controller (at I/O address 0x320 by default, set in the BAR0, other bars are 0 by default) a 0xFC command. It is mentioned in the ATA command list as being "Vendor Specific". ANyone has a list of Vendor Specific commands in the Western Digital IDE SuperBIOS v2.0?
Reply 2 of 16, by Harekiet
Rank DOSBox Author
DOSBox Author
Weird I made my ide emulation using the xtide bios and didn't really encounter anything strange.
The only one I error out on is
ATA_CMD_SET_FEATURES = 0xEF
I just give an error for that one and the rest are seek/read/write/verify/identity commands pretty much
Reply 4 of 16, by Harekiet
Rank DOSBox Author
DOSBox Author
I just set the error code to 1 and the status bit for having an error.
Reply 6 of 16, by Harekiet
Rank DOSBox Author
DOSBox Author
Nah I think it's some bitmask register of different error states but just having the error bit set seemed fine
Reply 7 of 16, by superfury
It seems to hang with sending the same command again and again (SEEK):
//ATA-1 harddisk emulation
#include "headers/types.h" //Basic types!
#include "headers/bios/io.h" //I/O support!
#include "headers/hardware/ports.h" //I/O port support!
#include "headers/emu/timers.h" //Timer support!
#include "headers/hardware/pci.h" //PCI support!
#include "headers/support/highrestimer.h" //High resolution timer support!
//Use WD BIOS by default assignment setting for compatibility?
#define WD_ATA
//Hard disk IRQ!
#define ATA_PRIMARYIRQ 14
#define ATA_SECONDARYIRQ 15
extern byte singlestep; //Enable single stepping when called?
typedef struct
word DeviceID;
word VendorID;
word Status;
word Command;
byte ClassCode;
byte Subclass;
byte ProgIF;
byte RevisionID;
byte BIST;
byte HeaderType;
byte LatencyTimer;
byte CacheLineSize;
uint_32 BAR[6]; //Our BARs!
uint_32 CardBusCISPointer;
word SubsystemID;
word SubsystemVendorID;
uint_32 ExpensionROMBaseAddress;
word ReservedLow;
byte ReservedHigh;
byte CapabilitiesPointer;
uint_32 Reserved;
byte MaxLatency;
byte MinGrant;
byte InterruptPIN;
byte InterruptLine;
} PCI_DEVICE; //The entire PCI data structure!
PCI_DEVICE PCI_IDE;
struct
byte longop; //Long operation instead of a normal one?
uint_32 datapos; //Data position?
uint_32 datablock; //How large is a data block to be refreshed?
uint_32 datasize; //Data size?
byte data[512]; //Full sector data!
word resultpos; //Result position?
word resultsize; //Result size?
byte result[512]; //Full result data!
byte command;
Show last 1040 lines
	byte commandstatus; //Do we have a command?
struct
union
struct
byte noaddressmark : 1;
byte track0notfound : 1;
byte commandaborted : 1;
byte mediachangerequested : 1;
byte idmarknotfound : 1;
byte mediachanged : 1;
byte uncorrectabledata : 1;
byte badsector : 1;
byte data;
} ERRORREGISTER;
union
struct
byte error : 1; //An error has occurred when 1!
byte index : 1; //Set once per disk revolution.
byte correcteddata : 1; //Data has been corrected.
byte datarequestready : 1; //Ready to transfer a word or byte of data between the host and the drive.
byte driveseekcomplete : 1; //Drive heads are settled on a track.
byte drivewritefault : 1; //Write fault status.
byte driveready : 1; //Ready to accept a command?
byte busy : 1; //The drive has access to the Command Block Registers.
byte data;
} STATUSREGISTER;
struct
union
struct
byte sectornumber; //LBA bits 0-7!
byte cylinderhigh; //LBA bits 8-15!
byte cylinderlow; //LBA bits 16-23!
union
byte drivehead; //LBA 24-27!
struct
byte head : 4; //What head?
byte slavedrive : 1; //What drive?
byte always1_1 : 1;
byte LBAMode_2 : 1; //LBA mode?
byte always1_2 : 1;
struct
byte LBAhigh : 6; //High 6 bits!
byte LBAMode : 1; //LBA mode?
byte always1_3 : 1;
uint_32 LBA; //LBA address in LBA mode (28 bits value)!
byte features;
byte sectorcount;
} PARAMETERS;
word driveparams[0x100]; //All drive parameters for a drive!
uint_32 current_LBA_address; //Current LBA address!
} Drive[2]; //Two drives!
union
struct
byte unused : 1;
byte nIEN : 1; //Disable interrupts when set or not the drive selected!
byte SRST : 1; //Reset!
byte data;
} DriveControlRegister;
union
byte data;
} DriveAddressRegister;
byte activedrive; //What drive are we currently?
byte DMAPending; //DMA pending?
byte TC; //Terminal count occurred in DMA transfer?
} ATA[2]; //Two channels of ATA drives!
uint_32 ATA_CHS2LBA(byte channel, byte slave, word cylinder, byte head, byte sector)
return ((cylinder*ATA[channel].Drive[slave].driveparams[55]) + head)*ATA[channel].Drive[slave].driveparams[56]; //Give the LBA value!
void ATA_LBA2CHS(byte channel, byte slave, uint_32 LBA, word *cylinder, byte *head, byte *sector)
uint_32 temp;
temp = (ATA[channel].Drive[slave].driveparams[55] * ATA[channel].Drive[slave].driveparams[56]); //Sectors per cylinder!
*cylinder = (word)(LBA / temp); //Cylinder!
LBA -= temp; //Decrease LBA to get heads&sectors!
temp = ATA[channel].Drive[slave].driveparams[56]; //SPT!
*head = (LBA / temp) & 0xF; //The head!
LBA -= temp; //Decrease LBA to get sectors!
*sector = (LBA & 0xFF); //The sector!
int ATA_Drives[2][2]; //All ATA mounted drives to disk conversion!
byte ATA_DrivesReverse[4][2]; //All Drive to ATA mounted drives conversion!
void ATA_IRQ(byte channel, byte slave)
if (!ATA[channel].DriveControlRegister.nIEN) //Allow interrupts?
switch (channel)
case 0: //Primary channel?
doirq(ATA_PRIMARYIRQ); //Execute the IRQ!
break;
case 1:
break;
default: //Unknown channel?
break;
void ATA_removeIRQ(byte channel, byte slave)
switch (channel)
removeirq(ATA_PRIMARYIRQ); //Execute the IRQ!
break;
case 1:
break;
break;
TicksHolder ATATicks;
struct
uint_64 ATA_tickstiming;
uint_64 ATA_tickstimeout; //How big a timeout are we talking about?
byte type; //Type of timer!
} IRQtimer[4]; //IRQ timer!
void updateATA() //ATA timing!
uint_64 passed = getuspassed_k(&ATATicks); //Get us passed!
if (passed) //Anything passed?
getuspassed(&ATATicks); //Passed some time!
int i;
for (i = 0;i < 4;i++) //Process all timers!
if (IRQtimer[i].ATA_tickstimeout) //Ticking?
IRQtimer[i].ATA_tickstiming += passed; //We've passed some!
if (IRQtimer[i].ATA_tickstiming >= IRQtimer[i].ATA_tickstimeout) //Expired?
IRQtimer[i].ATA_tickstimeout = 0; //Finished!
ATA_IRQ(i & 2, i & 1); //Do an IRQ from the source!
byte drive = (i & 1); //Drive!
byte channel = ((i & 2) >> 1); //Channel!
uint_32 getPORTaddress(byte channel)
switch (channel)
case 0: //First?
return (PCI_IDE.BAR[0] > 1) ? PCI_IDE.BAR[0] : 0x1F0; //Give the BAR!
break;
case 1: //Second?
return (PCI_IDE.BAR[2] > 1) ? PCI_IDE.BAR[2] : 0x170; //Give the BAR!
break;
default:
return ~0; //Error!
uint_32 getControlPORTaddress(byte channel)
switch (channel)
case 0: //First?
return (PCI_IDE.BAR[1] > 1) ? PCI_IDE.BAR[1] : 0x3F6; //Give the BAR!
break;
case 1: //Second?
return (PCI_IDE.BAR[3] > 1) ? PCI_IDE.BAR[3] : 0x376; //Give the BAR!
break;
default:
return ~0; //Error!
word get_cylinders(uint_64 disk_size)
return floor(disk_size / (63 * 16)); //How many cylinders!
word get_heads(uint_64 disk_size)
return 16;
word get_SPT(uint_64 disk_size)
return 63;
byte ATA_activeDrive(byte channel)
return ATA[channel].activedrive; //Give the drive or 0xFF if invalid!
byte ATA_resultIN(byte channel)
byte result;
switch (ATA[channel].command)
case 0xEC: //Identify?
result = ATA[channel].result[ATA[channel].resultpos++]; //Read the result byte!
if (ATA[channel].resultpos == ATA[channel].resultsize) //Fully read?
ATA[channel].commandstatus = 0; //Reset command!
return result; //Give the result byte!
break;
default: //Unknown?
break;
return 0; //Unknown data!
void ATA_increasesector(byte channel) //Increase the current sector to the next sector!
++ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address; //Increase the current sector!
void ATA_updatesector(byte channel) //Update the current sector!
word cylinder;
byte head, sector;
if (ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.LBAMode) //LBA mode?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.LBA &= 0xFFFFFFF; //Clear the LBA part!
ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address &= 0xFFFFFFF; //Truncate the address to it's size!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.LBA |= ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address; //Set the LBA part only!
else
uint_64 disk_size = ((ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[61] << 8) | ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[60]); //The size of the disk in sectors!
ATA_LBA2CHS(channel,ATA_activeDrive(channel),ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address, &cylinder, &head, &sector); //Convert the current LBA address into a CHS value!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh = ((cylinder >> 8) & 0xFF); //Cylinder high!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow = (cylinder&0xFF); //Cylinder low!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.head = head; //Head!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectornumber = sector; //Sector number!
byte ATA_readsector(byte channel) //Read the current sector set up!
if (ATA[channel].commandstatus == 1) //We're reading already?
if (!--ATA[channel].datasize) //Finished?
ATA_updatesector(channel); //Update the current sector!
ATA[channel].commandstatus = 0; //We're back in command mode!
return 1; //We're finished!
if (ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address >= disk_size) //Past the end of the disk?
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.idmarknotfound = 1; //Not found!
ATA[channel].commandstatus = 0xFF; //Error!
return 0; //Stop!
if (readdata(ATA_Drives[channel][ATA_activeDrive(channel)], &ATA[channel].data, (ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address << 9), 0x200)) //Read the data from disk?
ATA_increasesector(channel); //Increase the current sector!
ATA[channel].datablock = 0x200; //We're refreshing after this many bytes!
ATA[channel].datapos = 0; //Initialise our data position!
ATA[channel].commandstatus = 1; //Transferring data IN!
return 1; //Process the block!
else //Error reading?
return 0; //Stop!
byte ATA_writesector(byte channel)
if (writedata(ATA_Drives[channel][ATA_activeDrive(channel)], &ATA[channel].data, (ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address << 9), 0x200)) //Write the data to the disk?
//Process next sector!
else //Write failed?
if (drivereadonly(ATA_Drives[channel][ATA_activeDrive(channel)])) //R/O drive?
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.drivewritefault = 1; //Write fault!
else
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.uncorrectabledata = 1; //Not found!
return 0; //Finished!
byte ATA_dataIN(byte channel) //Byte read from data!
byte result;
switch (ATA[channel].command) //What command?
case 0x20:
case 0x21: //Read sectors?
result = ATA[channel].data[ATA[channel].datapos++]; //Read the data byte!
if (ATA[channel].datapos == ATA[channel].datablock) //Full block read?
if (ATA_readsector(channel)) //Next sector read?
ATA_IRQ(channel, ATA_activeDrive(channel)); //Give our requesting IRQ!
break;
default: //Unknown?
break;
void ATA_dataOUT(byte channel, byte data) //Byte written to data!
case 0x30: //Write sector(s) (w/retry)?
case 0x31: //Write sectors (w/o retry)?
ATA[channel].data[ATA[channel].datapos++] = data; //Write the data byte!
if (ATA_writesector(channel)) //Sector written and to write another sector?
break;
default: //Unknown?
break;
void ATA_executeCommand(byte channel, byte command) //Execute a command!
ATA[channel].longop = 0; //Default: no long operation!
uint_64 disk_size;
int drive;
byte temp;
switch (command) //What command?
case 0x90: //Execute drive diagnostic?
dolog("ATA", "DIAGNOSTICS:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
ATA[channel].Drive[0].ERRORREGISTER.data = 0x1; //OK!
ATA[channel].Drive[1].ERRORREGISTER.data = 0x1; //OK!
ATA[channel].Drive[0].STATUSREGISTER.error = 0; //Not an error!
ATA[channel].Drive[1].STATUSREGISTER.error = 0; //Not an error!
ATA[channel].commandstatus = 0; //Reset status!
ATA_IRQ(channel, ATA_activeDrive(channel)); //IRQ!
break;
case 0xDB: //Acnowledge media change?
dolog("ATA", "ACNMEDIACHANGE:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
switch (ATA_Drives[channel][ATA_activeDrive(channel)]) //What kind of drive?
case CDROM0:
case CDROM1: //CD-ROM?
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.mediachanged = 0; //Not changed anymore!
break;
default:
goto invalidcommand;
break;
case 0x10:
case 0x11:
case 0x12:
case 0x13:
case 0x14:
case 0x15:
case 0x16:
case 0x17:
case 0x18:
case 0x19:
case 0x1A:
case 0x1B:
case 0x1C:
case 0x1D:
case 0x1E:
case 0x1F: //Recalibrate?
dolog("ATA", "RECALIBRATE:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
temp = (command & 0xF); //???
if (has_drive(ATA_Drives[channel][ATA_activeDrive(channel)]) && (ATA_Drives[channel][ATA_activeDrive(channel)]>=HDD0) && (ATA_Drives[channel][ATA_activeDrive(channel)]<=HDD1)) //Gotten drive?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow = 0; //Clear cylinder #!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.driveseekcomplete = 1; //We've completed seeking!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.error = 0; //Not an error!
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.data = 0; //No error!
ATA_IRQ(channel, ATA_activeDrive(channel)); //Execute the IRQ!
else
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.driveseekcomplete = 0; //We've not completed seeking!
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.track0notfound = 1; //Track 0 couldn't be found!
break;
case 0x70:
case 0x71:
case 0x72:
case 0x73:
case 0x74:
case 0x75:
case 0x76:
case 0x77:
case 0x78:
case 0x79:
case 0x7A:
case 0x7B:
case 0x7C:
case 0x7D:
case 0x7E:
case 0x7F: //Seek?
dolog("ATA", "SEEK:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
temp = (command & 0xF); //The head to select!
if (((ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh << 8) | ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow) < ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[54]) //Cylinder correct?
if (temp < ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[55]) //Head within range?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.head = temp; //Set the head we use!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.data = 0; //No error!
ATA_IRQ(channel, ATA_activeDrive(channel)); //Execute an IRQ!
else goto invalidcommand; //Error out!
break;
case 0x22: //Read long (w/retry)?
case 0x23: //Read long (w/o retry)?
ATA[channel].longop = 1; //Long operation!
case 0x20: //Read sector(s) (w/retry)?
case 0x21: //Read sector(s) (w/o retry)?
dolog("ATA", "READ(long:%i):%i,%i=%02X", ATA[channel].longop,channel, ATA_activeDrive(channel), command);
ATA[channel].datasize = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectorcount; //Load sector count!
if (ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.LBAMode) //Are we in LBA mode?
ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address = (ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.LBA & 0xFFFFFFF); //The LBA address!
else //Normal CHS address?
ATA[channel].Drive[ATA_activeDrive(channel)].current_LBA_address = ATA_CHS2LBA(channel,ATA_activeDrive(channel),
((ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh << 8) | (ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow)),
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.head,
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectornumber); //The LBA address based on the CHS address!
if (ATA_readsector(channel)) //OK?
break;
case 0x32: //Write long (w/retry)?
case 0x33: //Write long (w/o retry)?
dolog("ATA", "WRITE(LONG:%i):%i,%i=%02X",ATA[channel].longop, channel, ATA_activeDrive(channel), command);
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectornumber,
ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[55],
(uint_64)disk_size); //The LBA address based on the CHS address!
ATA[channel].commandstatus = 2; //Transferring data OUT!
break;
case 0x91: //Initialise device parameters?
dolog("ATA", "INITDRVPARAMS:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
ATA[channel].commandstatus = 0; //Requesting command again!
ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[55] = (ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.head + 1); //Set the current maximum head!
ATA[channel].Drive[ATA_activeDrive(channel)].driveparams[56] = (ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectorcount); //Set the current sectors per track!
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.data = 0; //No errors!
break;
case 0xEC: //Identify drive?
dolog("ATA", "IDENTIFY:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
ATA[channel].command = 0xEC; //We're running this command!
memcpy(&ATA[channel].result, &ATA[channel].Drive[ATA_activeDrive(channel)].driveparams, sizeof(ATA[channel].Drive[ATA_activeDrive(channel)].driveparams)); //Set drive parameters currently set!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.data = 0; //Clear any errors!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow = 0; //Needs to be 0 to detect!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh = 0; //Needs to be 0 to detect!
//Finish up!
ATA[channel].resultpos = 0; //Initialise data position for the result!
ATA[channel].resultsize = sizeof(ATA[channel].Drive[ATA_activeDrive(channel)].driveparams); //512 byte result!
ATA[channel].commandstatus = 3; //We're requesting data to be read!
ATA_IRQ(channel, ATA_activeDrive(channel)); //Execute an IRQ from us!
break;
case 0xDA: //Get media status?
dolog("ATA", "GETMEDIASTATUS:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
if (ATA_Drives[channel][ATA_activeDrive(channel)] >= CDROM0) //CD-ROM drive?
drive = ATA_Drives[channel][ATA_activeDrive(channel)]; //Load the drive identifier!
if (has_drive(drive)) //Drive inserted?
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.uncorrectabledata = drivereadonly(drive); //Are we read-only!
else
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.uncorrectabledata = 0; //Are we read-only!
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.mediachanged = 0; //Not anymore!
ATA_IRQ(channel, ATA_activeDrive(channel)); //Raise IRQ!
break;
case 0xDC: //BIOS - post-boot?
case 0xDD: //BIOS - pre-boot?
case 0x50: //Format track?
case 0x97:
case 0xE3: //Idle?
case 0x95:
case 0xE1: //Idle immediate?
case 0x00: //NOP?
case 0xE4: //Read buffer?
case 0xC8: //Read DMA (w/retry)?
case 0xC9: //Read DMA (w/o retry)?
case 0xC4: //Read multiple?
case 0x40: //Read verify sector(s) (w/retry)?
case 0x41: //Read verify sector(s) (w/o retry)?
case 0xEF: //Set features?
case 0xC6: //Set multiple mode?
case 0x99:
case 0xE6: //Sleep?
case 0x96:
case 0xE2: //Standby?
case 0x94:
case 0xE0: //Standby immediate?
case 0xE8: //Write buffer?
case 0xCA: //Write DMA (w/retry)?
case 0xCB: //Write DMA (w/o retry)?
case 0xC5: //Write multiple?
case 0xE9: //Write same?
case 0x3C: //Write verify?
default: //Unknown command?
//Invalid command?
invalidcommand:
dolog("ATA", "INVALIDCOMMAND:%i,%i=%02X", channel, ATA_activeDrive(channel), command);
ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.data = 1; //Reset error register!
ATA[channel].commandstatus = 0xFF; //Move to error mode!
break;
void ATA_updateStatus(byte channel)
switch (ATA[channel].commandstatus) //What command status?
case 0: //Ready for command?
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.busy = 0; //Not busy! You can write to the CBRs!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.driveready = 1; //We're ready to process a command!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.datarequestready = 0; //Not requesting data to transfer!
break;
case 1: //Transferring data IN?
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.datarequestready = 1; //We're requesting data to transfer!
break;
case 2: //Transferring data OUT?
break;
case 3: //Transferring result?
break;
case 4: //Busy waiting?
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.busy = 1; //Busy! You can write to the CBRs!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.driveready = 0; //We're ready to process a command!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.datarequestready = 0; //We're requesting data to transfer!
break;
default: //Unknown?
case 0xFF: //Error?
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.datarequestready = 0; //We're not requesting data to transfer!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.error = 1; //Error!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.correcteddata = 0; //Not corrected data!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.index = 0;
break;
void ATA_writedata(byte channel, byte value)
if (!ATA_Drives[channel][ATA_activeDrive(channel)]) //Invalid drive?
return; //OK!
switch (ATA[channel].commandstatus) //Current status?
case 2: //DATA OUT?
ATA_dataOUT(channel,value); //Read data!
break;
default: //Unknown status?
break;
byte outATA16(word port, word value)
byte channel = 0; //What channel?
if (port != getPORTaddress(channel)) //Primary channel?
channel = 1; //Try secondary channel!
if (port != getPORTaddress(channel)) //Secondary channel?
return 0; //Not our port?
ATA_writedata(channel, (value&0xFF)); //Write the data low!
ATA_writedata(channel, ((value >> 8) & 0xFF)); //Write the data high!
return 1;
byte outATA8(word port, byte value)
if ((port<getPORTaddress(channel)) || (port>getPORTaddress(channel)+0xD)) //Primary channel?
if ((port >= getControlPORTaddress(channel)) && (port <= getControlPORTaddress(channel)+1)) goto port3_write;
if ((port<getPORTaddress(channel)) || (port>getPORTaddress(channel) + 0xD)) //Secondary channel?
if ((port >= getControlPORTaddress(channel)) && (port <= getControlPORTaddress(channel) + 1)) goto port3_write;
port -= getPORTaddress(channel); //Get the port from the base!
switch (port) //What port?
case 0: //DATA?
ATA_writedata(channel, value); //Write the data!
return 1;
break;
case 1: //Features?
//ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.features = value; //Use the set data! Ignore!
return 1; //OK!
break;
case 2: //Sector count?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectorcount = value; //Set sector count!
return 1; //OK!
break;
case 3: //Sector number?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectornumber = value; //Set sector number!
return 1; //OK!
break;
case 4: //Cylinder low?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow = value; //Set cylinder low!
return 1; //OK!
break;
case 5: //Cylinder high?
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh = value; //Set cylinder high!
return 1; //OK!
break;
case 6: //Drive/head?
ATA[channel].activedrive = (value >> 4) & 1; //The active drive!
ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.drivehead = value; //Set drive head!
return 1; //OK!
break;
case 7: //Command?
ATA_executeCommand(channel,value); //Execute a command!
return 1; //OK!
break;
default: //Unsupported!
break;
return 0; //Safety!
port3_write: //Special port #3?
port -= getControlPORTaddress(channel); //Get the port from the base!
return 1; //OK!
case 0: //Control register?
ATA[channel].DriveControlRegister.data = value; //Give the drive control register!
return 1; //OK!
break;
break;
return 0; //Unsupported!
void ATA_readdata(byte channel, byte *result)
*result = 0; //No result!
return; //Abort!
case 1: //DATA IN?
*result = ATA_dataIN(channel); //Read data!
break;
case 3: //Result IN?
*result = ATA_resultIN(channel); //Read result!
break;
*result = 0; //Unsupported for now!
break;
byte inATA16(word port, word *result)
if (port!=getPORTaddress(channel)) //Primary channel?
if (port!=getPORTaddress(channel)) //Secondary channel?
byte buffer;
word resultbuffer;
ATA_readdata(channel, &buffer); //Read the low data!
resultbuffer = buffer; //Load the low byte!
ATA_readdata(channel, &buffer); //Read the high data!
resultbuffer |= (buffer << 8); //Load the high byte!
*result = resultbuffer; //Set the result!
return 1;
byte inATA8(word port, byte *result)
if ((port<getPORTaddress(channel)) || (port>getPORTaddress(channel) + 0xD)) //Primary channel?
if ((port >= getControlPORTaddress(channel)) && (port <= getControlPORTaddress(channel) + 1)) goto port3_read;
*result = 0; //Give 0: we're not present!
return 1; //OK!
case 0: //DATA?
ATA_readdata(channel, result); //Read the data!
return 1;
break;
case 1: //Error register?
*result = ATA[channel].Drive[ATA_activeDrive(channel)].ERRORREGISTER.data; //Error register!
return 1;
break;
*result = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectorcount; //Get sector count!
return 1;
break;
*result = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.sectornumber; //Get sector number!
return 1; //OK!
break;
*result = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderlow; //Get cylinder low!
return 1; //OK!
break;
*result = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.cylinderhigh; //Get cylinder high!
return 1; //OK!
break;
*result = ATA[channel].Drive[ATA_activeDrive(channel)].PARAMETERS.drivehead; //Get drive/head!
return 1; //OK!
break;
case 7: //Status?
ATA_updateStatus(channel); //Update the status register if needed!
ATA_removeIRQ(channel,ATA_activeDrive(channel)); //Acnowledge IRQ!
*result = ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.data; //Get status!
ATA[channel].Drive[ATA_activeDrive(channel)].STATUSREGISTER.drivewritefault = 0; //Reset write fault flag!
return 1; //OK!
break;
default: //Unsupported?
break;
port3_read: //Special port #3?
return 1; //OK!
case 0: //Alternate status register?
return 1; //OK!
break;
case 1: //Drive address register?
*result = ATA[channel].DriveAddressRegister.data; //Give the data!
return 1; //OK!
break;
break;
byte CDROM_DiskChanged = 0;
void ATA_DiskChanged(int disk)
byte disk_ATA, disk_channel, disk_nr;
switch (disk) //What disk?
//Four disk numbers!
case HDD0:
disk_nr = 0;
break;
case HDD1:
disk_nr = 1;
break;
case CDROM0:
disk_nr = 2;
break;
case CDROM1:
disk_nr = 3;
break;
return; //Abort!
disk_channel = ATA_DrivesReverse[disk_nr][0]; //The channel of the disk!
disk_ATA = ATA_DrivesReverse[disk_nr][1]; //The master/slave of the disk!
if ((disk_nr >= 2) && CDROM_DiskChanged) //CDROM changed?
ATA[disk_channel].Drive[disk_ATA].ERRORREGISTER.mediachanged = 1; //We've changed media!
if ((disk_channel == 0xFF) || (disk_ATA == 0xFF)) return; //Not mounted!
uint_64 disk_size;
switch (disk)
case HDD0: //HDD0 changed?
case HDD1: //HDD1 changed?
case CDROM0: //CDROM0 changed?
case CDROM1: //CDROM1 changed?
if (has_drive(disk)) //Do we even have this drive?
disk_size = disksize(disk); //Get the disk's size!
disk_size >>= 9; //Get the disk size in sectors!
ATA[disk_channel].Drive[disk_ATA].driveparams[0] = ((disk==CDROM0)||(disk==CDROM1))? ((2 << 14) | (5 << 8) | (1 << 7) | (2 << 5) | (0 << 0)):0x40; //Hard sectored, Fixed drive/CDROM drive!
ATA[disk_channel].Drive[disk_ATA].driveparams[1] = ATA[disk_channel].Drive[disk_ATA].driveparams[54] = get_cylinders(disk_size); //1=Number of cylinders
ATA[disk_channel].Drive[disk_ATA].driveparams[2] = ATA[disk_channel].Drive[disk_ATA].driveparams[55] = get_heads(disk_size); //3=Number of heads
ATA[disk_channel].Drive[disk_ATA].driveparams[6] = ATA[disk_channel].Drive[disk_ATA].driveparams[56] = get_SPT(disk_size); //6=Sectors per track
ATA[disk_channel].Drive[disk_ATA].driveparams[20] = 1; //One transfer at a time!
ATA[disk_channel].Drive[disk_ATA].driveparams[21] = 1; //512 byte buffer!
ATA[disk_channel].Drive[disk_ATA].driveparams[49] = 0x200; //LBA supported, DMA unsupported!
ATA[disk_channel].Drive[disk_ATA].driveparams[53] = 1; //Using soft-sectoring!
ATA[disk_channel].Drive[disk_ATA].driveparams[60] = (disk_size & 0xFFFF); //Number of addressable sectors, low word!
ATA[disk_channel].Drive[disk_ATA].driveparams[61] = (disk_size >> 16); //Number of addressable sectors, high word!
else //Drive not inserted?
memset(ATA[disk_channel].Drive[disk_ATA].driveparams, 0, sizeof(ATA[disk_channel].Drive[disk_ATA].driveparams)); //Clear the information on the drive: it's non-existant!
break;
default: //Unknown?
break;
void initATA()
initTicksHolder(&ATATicks);
memset(&ATA, 0, sizeof(ATA)); //Initialise our data!
memset(&IRQtimer, 0, sizeof(IRQtimer)); //Init timers!
//We don't register a disk change handler, because ATA doesn't change disks when running!
//8-bits ports!
register_PORTIN(&inATA8);
register_PORTOUT(&outATA8);
//16-bits port!
register_PORTINW(&inATA16);
register_PORTOUTW(&outATA16);
//We don't implement DMA: this is done by our own DMA controller!
//First, detect HDDs!
memset(ATA_Drives, 0, sizeof(ATA_Drives)); //Init drives to unused!
memset(ATA_DrivesReverse, 0, sizeof(ATA_DrivesReverse)); //Init reverse drives to unused!
byte CDROM_channel = 1; //CDROM is the second channel by default!
if (has_drive(HDD0)) //Have HDD0?
ATA_Drives[0][0] = HDD0; //Mount HDD0!
if (has_drive(HDD1)) //Have HDD1?
ATA_Drives[0][1] = HDD1; //Mount HDD1!
else if (has_drive(HDD1)) //Have HDD1?
ATA_Drives[0][0] = HDD1; //Mount HDD1!
else
CDROM_channel = 0; //Move CDROM to primary channel!
ATA_Drives[CDROM_channel][0] = CDROM0; //CDROM0 always present as master!
ATA_Drives[CDROM_channel][1] = CDROM1; //CDROM1 always present as master!
int i,j,k;
int disk_reverse[4] = { HDD0,HDD1,CDROM0,CDROM1 }; //Our reverse lookup information values!
for (i = 0;i < 4;i++) //Check all drives mounted!
ATA_DrivesReverse[i][0] = 0xFF; //Unassigned!
ATA_DrivesReverse[i][1] = 0xFF; //Unassigned!
for (j = 0;j < 2;j++)
for (k = 0;k < 2;k++)
if (ATA_Drives[j][k] == disk_reverse[i]) //Found?
ATA_DrivesReverse[i][0] = j;
ATA_DrivesReverse[i][1] = k; //Load reverse lookup!
//Now, apply the basic disk information (disk change/initialisation of parameters)!
register_DISKCHANGE(HDD0, &ATA_DiskChanged);
register_DISKCHANGE(HDD1, &ATA_DiskChanged);
register_DISKCHANGE(CDROM0, &ATA_DiskChanged);
register_DISKCHANGE(CDROM1, &ATA_DiskChanged);
CDROM_DiskChanged = 0; //Init!
ATA_DiskChanged(HDD0); //Init HDD0!
ATA_DiskChanged(HDD1); //Init HDD1!
ATA_DiskChanged(CDROM0); //Init HDD0!
ATA_DiskChanged(CDROM1); //Init HDD1!
CDROM_DiskChanged = 1; //We're changing when updating!
memset(&PCI_IDE, 0, sizeof(PCI_IDE)); //Initialise to 0!
register_PCI(&PCI_IDE, sizeof(PCI_IDE)); //Register the PCI data area!
//Initialise our data area!
PCI_IDE.DeviceID = 1;
PCI_IDE.VendorID = 1; //DEVICEID::VENDORID: We're a ATA device!
PCI_IDE.ProgIF = 0x80; //We use our own set interrupts and we're a parallel ATA controller!
#ifdef WD_ATA
PCI_IDE.BAR[0] = 0x300; //Single controller only!
#endif
Can you tell why this is?
Reply 8 of 16, by Harekiet
Rank DOSBox Author
DOSBox Author
Well that code looks to horrible to even read it, really why not just use some temporary pointer to the active ata object instead of the endless copy and pasting.
I think I just ignore the seek command and signal the irq that it completed, should probably check for it being within limits but shouldn't go too crazy with implementing shit you can't test anyway.
Reply 9 of 16, by superfury
OK. Here's the link from the current version: https://bitbucket.org/superfury/x86emu/src/50 … ide.c?at=master
Can you see why it keeps resending the SEEK command infinitely? From debugging it executes the seek and raises the IRQ, but for some reason the BIOS doesn't detect it (IRQ14) or has some reason to request again I don't yet know. First is a 0xEC IDENTIFY command, next a RECALIBRATE command, then infinite SEEKs. The ATA_updateStatus updates the status register when it's read (both when using the status and alt. status port). The ATA[controller].commandstatus is the current expected state (command ready, read data, write data, result(alt read in data), busy and error(0xFF)).
Edit: Fixed 2 bugs: Invalid secondary IRQ and LBA incorrectly truncated:
https://bitbucket.org/superfury/x86emu/src/55 … ide.c?at=master
Reply 10 of 16, by ripa
byte result;
case 0x20:
break;
default: //Unknown?
break;
What's the purpose of 'result'? Pay attention to the warnings your compiler is (or should be) printing.
Reply 11 of 16, by superfury
Result acts as a little buffer before returning: after the data is read into buffer, it checks if the buffer needs to be refilled, refills if needed, raises an IRQ when needed and then return the byte read (in it's current case: a byte from a hard disk sector).
Btw, according to me there should be no 'warning': The variable is used in a case and a result is given at all times. The compiler doesn't care about much more than that afaik.
Edit: Fixed! Latest version:
Reply 12 of 16, by superfury
I've removed the resultIN function and merged it with the dataIN function (as they're exactly the same). I'm currently getting the following log:
0:00:12:30.7.0286: IDENTIFY:0,0=EC
0:00:12:30.7.0646: RECALIBRATE:0,0=10
0:00:12:30.7.0743: Recalibrated!
0:00:12:31.0.0462: SEEK:0,0=7D
0:00:12:31.0.0464: Seeked!
0:00:12:31.3.0285: SEEK:0,0=7D
0:00:12:31.3.0288: Seeked!
0:00:12:31.6.0049: SEEK:0,0=7D
0:00:12:31.6.0052: Seeked!
0:00:12:31.8.0835: SEEK:0,0=7D
0:00:12:31.8.0838: Seeked!
0:00:12:32.1.0577: SEEK:0,0=7D
0:00:12:32.1.0580: Seeked!
0:00:12:32.4.0719: SEEK:0,0=7D
0:00:12:32.4.0722: Seeked!
0:00:12:32.7.0699: SEEK:0,0=7D
0:00:12:32.7.0701: Seeked!
The seeks continue forever (infinite loop). Anyone knows why this is happening?
My latest source code of my ATA emulation:
https://bitbucket.org/superfury/x86emu/src/7b … ide.c?at=master
There's a ATA hard disk at Primary Master, No primary slave, Two CD-ROM drives at Secondary Master&Slave.
Reply 13 of 16, by superfury
I'm trying to get the BIOS working with my emulator, but it needs some settings to do that. There's a program given with the software (xtidecfg.com), but it won't apply the settings I'm letting it detect and adjusted (for fixing the wrong settings). I think I need to emulate the flashing of the EEPROM in order to apply the settings (strangely it doesn't save it's settings on the CMOS). I need to have some information on how the software enabled writes into the EEPROM. Anyone knows how it does that? Does it do some special sequence of writes to memory? Or does it use some hardware I/O in order to archieve that?
Reply 14 of 16, by superfury
I've added support for flashing OPTROM files (using the Atmel AT28C64B documentation) and flashed the new BIOS settings with the XTIDECFG 2864 chip option (normal 8k chip). It now flashes my settings together with the XT BIOS (set up for ISA IDE mode on both primary and secondary master and slave). It now starts to execute:
0:00:12:58.6.0149: IDENTIFY:0,0=EC
0:00:13:26.6.0447: IDENTIFY:1,0=EC
0:00:13:34.3.0509: IDENTIFY:1,1=EC
I've set the BIOS up to use IDE ATA/PCI. It executes the identify commands and after that says it's trying to boot from a hard disk, but I don't see any reads from disk (except from those identify commands).
My current version:
https://bitbucket.org/superfury/x86emu/src/96 … ide.c?at=master
Reply 15 of 16, by superfury
My current version:
https://bitbucket.org/superfury/x86emu/src/ed … ide.c?at=master
Anyone knows why the XT-IDE BIOS configurator isn't detecting my HDD and CD-ROM drives?
Reply 16 of 16, by superfury
This is my latest version:
https://bitbucket.org/superfury/x86emu/src/5a … ide.c?at=master
MS-DOS can partition, format and read/write it without errors now. For some reason the XT-IDE ROM refuses to boot from the harddisk (I've used FDISK and FORMAT /S on it with MS-DOS 5.0). It gives a error 80h (Which should be a timeout error?). According to my logs, the last command executed was a seek command. Anyone knows why it's 'timing out'? I don't see a invalid command in the log.
