First post, by superfury
I notice that Windows 3.0 crashes when starting (after the loading screen, it crashes back to the MS-DOS prompt).
I notice that the following instruction raises a Divide by 0 error 3 times before crashing back to the MS-DOS prompt (MS-DOS 5.0):
2999:419F IDIVW BX
DX=0
AX=0
BX=0
The log from after the first divide error:
debugger.log
87.18 KiB
42 downloads
Debugger log from the first IDIV error to the next when loading Windows 3.0.
Anyone knows why this happens? Earlier builds didn't have this problem (build 31/12/2015 and earlier). I've tried reversing the 8086 CPU back to older versions before 31/12/2015, but it will still crash.
When trying to run Windows 3.0 with the 80186/80188 CPU it will run without problems (only difference should be the addition of more instructions and MOV CS exception, as well as a Invalid opcode exception (interrupt 6h)).
Edit: When enabling the 80186+ invalid opcode exception instead of the 8086 NOP version, I notice that it's trying to execute the 80186+ opcode C1 (80186+ opcode)? This is one of the shift/rotate instructions, ignored on my 8086/8088 emulation. Is this the cause that crashes Windows 3.0?
Edit: When disabling all device drivers (latest mouse.sys and Expanded memory manager), it seems Windows keeps repeating calling interrupt 3Fh with AX>0xFFF7(I believe it was 0xFFF8, loading DLL library?)
UniPCemu Git repository
