First post, by Guest
VDMsound can run Ultima Underworld and manages to make the music sound the same as it did in DOS (i.e. the same instruments). However, midi files of the music sound different. Is this because they have been programmed again from scratch? In that case is the original music only available inside the game (so you can't get an exact-sounding midi file)?
