First post, by Nic-93
For somereason it keep's doing a reset after the memory counting and when it had found floopy drive #2 it sem's to get stuck with the numlock key lit up.
Reply 1 of 3, by alexanrs
1- Check for leaking batteries
2- Try disconnecting the floppy drives and HDDs and see if the behaviour changes
3- Try changing the memory sticks (or at least reseating them).
Reply 2 of 3, by Nic-93
The first answer dont i have problem's with, the clock is keeping the time with out problem's.
so the 2 other's are the possible subject''s.
Reply 3 of 3, by Nic-93
The problem sem to be solved now, it was the cable's being a jerk.
