First post, by Anticept
Will pentium class core be supported in doxbox? I have a couple games that use the pentium core in a dos environment.
Ex. Terminal Velocity
BTW, Thanks for such a great program!
Anticept
Anticept
Terminal Velocity works fine on a 486.
The "pentium core"?
As far as I know all "pentium" games worked on my 486DX4/100 back in the day. The Pentium had more cache and a wider bus and of course MMX, which of course doesn't matter for DosBox....it is possible that some games may require MMX tho.
I never said that it doesn't work.
It is just that my large monitor makes the game REALLY ugly. I would like to be able to use the higher graphic settings so that it wont look like a bunch of fuzzy ships floating around. However, when I set it to pentium, the game lags bad. I even turned the clock speed way up but it didn't help. 😒
Unfortunately, just because DOSBox emulates everything (and hence its broad compatibility range), it needs a powerful machine. I think obtaining Pentium equivalent speeds must be something difficult to achieve with current hardware.
PS - Did you try running the game using VDMSound or even VirtualPC?, where your real cpu speed is the speed you get.
I'll have to look at TV again but I believe when you switch to "pentium" it just switches to higher VESA modes.
SVGA support (640 x 480 resolution). This is a Pentium-recommended mode
Special Pentium mode to improve textured graphics.
Anyone ever use the S3 Virge patch for TV? I only ever used TV with I think an old Cirrus Logic and a Trident card back in the day....Did it provide any kind of enhancement to TV or just speed improvements?
Man, what a mess 3D acceleration was back in the day... VQuake, and that "optimized" version of Descent 2 for S3 Virge that was a total joke. Thank god we're beyond that!
Now if you'll excuse me, I'm going to go play some Half-Life 2 on my ATI machine, and then maybe some Doom 3 on my Nvidia machine 😁
Original Pentium had no MMX nor had the Pentium Pro. The Pentium II, though based on the Pentium Pro, had MMX as well as later "Pentium MMX" P55C which had a different internal arrangement than traditional P54C Pentium
The Sole Survivor.
Find me on efnet #oldgames
IIRC, there was some kind of bilinear filtering in the S3 Virge version of TV. I only had a demo bundeled with the card, and I didn't played it much, so I'm not sure..
wrote:that "optimized" version of Descent 2 for S3 Virge that was a total joke.
S3 ViRGE: The 3-decelerator. (IIRC part of the problem, other than the obvious of the S3V being a piece of crap, was running in 16 bit colour--just plain more data to push. I believe someone tried to claim it was running at 800x600 though!)
