fede2222 wrote on 2016-06-27, 04:14:Yeah!!! coolhaken!.. i test on real hardware and it works!! […]
With HGCIBM or SIMCGA 4.2 i have the problemas described in the thread, but with this PARTICULAR SIMCGA works perfectly... Yes, the text is missing..
I don't remember the text, but i remember the image streched vertically like the screenshot... with HGCIBM is not streched and use "full" screen
Thank you very much!!!
Konc
I'm using real hardware: AT286 8-12Mhz + Hercules Clone Card
If you add R parameter to the command line it resets the config and you can select different options.. can you try that... i forced CGA mode
I downloaded the "BBSIMCGA.COM" file and, indeed was the ONLY CGA emulator capable of running Bubble Bobble on my computer (I tried several few).
I have a 386DX at 40 MhZ with a Winbond Hercules Graphic Card and Monochrome Monitor.
The problem is that the framerate is broken in my case; at first will start running too fast and then too slow, unplayable.
But indeed was the only emulator capable of launching the game.
I tried the BBSIMCGA emulator for other titles that I have (Stunts, Spectrum Holobyte's Tetris, Sokoban) and it works PERFECTLY!!!
Although I'm not sure how to use the "r" parameter that you mention to reset the emulation.
In my case, the emulation will always be on until I restart the computer.
Can you tell me how do you reset the emulation?
Thanks!!!
Cyrix 80486DX 80Mhz, 32mb RAM, 1024kb Trident VGA, Sound Blaster 16, 4GB HDD, 3 1/2 floppy disk drive + Creative CD-ROM drive unit.
Intel 80386 DX 40Mhz, 8MB RAM, Trident VGA 256kb, Sound Blaster 16 CT 2950, 525MB HDD, 3 1/2 floppy, 52x CD-ROM .
