Doom 3 performance
First post, by bakcom
Has anyone got consistent 60fps out of Doom 3 with the highest antialiasing setting (x16 or x8)?
I'm running it on a GTX 750. Settings: "Ultra" quality, 1920x1080, x8 or x16 AA (ingame setting), vsync.
It can't stick to 60fps. At the very beginning of the game, looking toward the stairs immediately drops to 30fps. Looking the other way it's 60fps.
I suspect it's an old-engine compatibility or setting issue because even the menus, before starting a new game, are at 30fps.
With x4 AA, looking at the stairs in the beginning area, it's about 50fps. Not perfect, but good enough. The menus are at 60fps.
But x4 still looks a bit jagged.
Reply 1 of 18, by SpooferJahk
Not sure if it is a driver issue but I had strange performance issues with using in game AA on a system with a GTX 770. My only solution for running the game at a smooth 60 FPS with AA is to use SweetFX 2.0 and use the SMAA option. It is not a perfect AA solution but it is better than nothing.
Same applies to Quake 4 and possibly Prey, might have something to do with the engine with modern hardware or something to that effect.
Reply 2 of 18, by bakcom
Strange how?
I haven't tried SMAA. Do you find it looks better than Doom 3's native x4 AA?
The driver I'm using is something like 347.xx (not on that computer right now to check), on WinXP.
BTW, a reference point with a 2004-era graphics card from AnandTech...
GeForce 6800 Ultra Extreme (silly name), at 1600x1200, Ultra quality, x4 AA, runs the game at about 40fps.
GTX 750 non-TI should be multiple times faster.
Reply 3 of 18, by SpooferJahk
bakcom wrote:
Strange how? I haven't tried SMAA. Do you find it looks better than Doom 3's native x4 AA? […]
Strange how?
When I mean strange, I mean when combat occurred on my end the game would slow down, not lag or stutter, literally slow down like bullet time in Max Payne. It only happened when I used AA in the game or forced it in my GPU control panel.
SMAA is good, but it does not beat Doom 3's native AA since it is more of a filter than an image enhancement. There's still aliasing but it at least gets ride of the more jagged stuff.
Reply 4 of 18, by Errius
I tried this with GTX 550 SLI at 1920x1080 with all settings at max, including x16 AA. I get 45-50 fps when looking at the stairs before moving. It doesn't drop below that while walking towards the door, but when I turn around it drops to about 35 when I look at the guy on the bench.
Is this too much voodoo?
Reply 5 of 18, by bakcom
Perhaps you set com_fixedTic to 1?
Unusual setup. What would you say it is equivalent to in a single card?
Reply 6 of 18, by Errius
Dunno, but this setup scores 5101 in 3DMark 11. (2933 for single card.)
Reply 7 of 18, by SpooferJahk
This is with that option on, even with it off that causes problems in other ways like odd stuttering on my end.
Reply 8 of 18, by bakcom
The fps you get is with vsync on? I should check with Fraps what's going on in more detail rather than rely on the game's counter. The 50fps I get (with x4 AA) is actually an odd figure for standing still in the game with vsync on. If correct, it would imply a rate that changes between 30 and 60fps in a regular pattern.
By default I had regular stuttering/hiccups, quite an odd bug that apparently many experience. Setting com_fixedTic to 1 fixes or at least improves it, but causes motion slowdowns when the frame rate is lower than 60. The best solution I found, instead, is setting com_preciseTic to 0.
Reply 9 of 18, by Errius
All settings on "yes" including v-sync. I have brightness and gamma to the max, don't know if that makes a difference.
Reply 10 of 18, by MrEWhite
Runs fine here with 4x AA, (I find anything over that too blurry) I am using a GTX 1070 though. The only time it goes under 60 is when I noclip out of the map and look at everything.
Reply 11 of 18, by bakcom
AAx4 is generally fine here as well. It's the x8 and x16 modes that are too slow.
There are a few spots where x4 drops down to consistent 30fps, but it's not common. In one spot I disabled vsync to see the effect, and the result was about 50 fps. I guess frames there draw consistently a few ms too long for 60Hz.
I didn't find x8/x16 blurry, maybe something renders differently on your setup? You can try changing the game's texture mipmap bias by setting image_lodbias to small negative values. Maybe -0.5 or -1. You can also try forcing it in the driver using Nvidia Inspector or similar.
Reply 12 of 18, by MrEWhite
Nah, just in general I don't like using AA over 4.
Reply 13 of 18, by tincup
@ bakcom - Which version of D3 are you running? On modern rigs v1 can confer a 10-15% (or more) frame boost over the 1.2 and 1.3+ patches. Thread on the ongoing D3 benchmark extravaganza here:
Doom 3 timedemo shootout with period correct hardware.
Reply 14 of 18, by bakcom
Thanks. It was with the latest v1.31. Haven't tried older versions, but even if faster I would want the fixes.
Performance could be better in parts, but generally it was fine.
Reply 15 of 18, by Presbytier
I have not had any issues with Doom 3, but I am also running a GTX 1080. Occasionally I saw some stuttering but that does not seem to be an issue after the Anniversary update.
"Never pay more than 20 dollars for a computer game" - Guybrush Threepwood
Reply 16 of 18, by gameragodzilla
Turn on FXAA and see if that fixes the issue. For some bizarre reason, antialiasing causes major frame drops unless you have FXAA enabled, at which point it will apply all of those settings while still maintaining a smooth 60fps. At least for me, anyways. Dunno about the others but it's worth a shot.
Reply 17 of 18, by Iris030380
1920x1080 with all that AA does need quite a bit of grunt. Those settings brought the 6800GT's and X1950's to their knees, even at much lower resolutions.
I played through Doom III again a few years ago on a GTX760 with a decent overclock and an IvyBridge i5. It held 60fps without a problem, averaging around 116fps in timedemo, but that was without AA. Factor in 30% fps reduction for the AA, and another 30% for the 750Ti being slower than the 760 by quite a margin, and it seems you're getting about the right framerate. Play it without AA! 🤣
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 18 of 18, by bakcom
It's a type of antialiasing that's less taxing than the default MSAA. I'm not sure I like it, but I'll have a look again the next time.
There could be other bottlenecks in addition. Even in games older and simpler than Doom 3 you don't always get 60FPS with AA. For example, Max Payne (1) at 1440x1080, which I played recently.
