First post, by boxpressed
- Oldbie
Simple question: Can you load soundfonts for use in DOS games (played via Windows DOS box) with SB Live?
I recall that I used to be able to do this, but I recently installed an SB0060 on a BX system, and regardless of what soundfont I load via AudioHQ, the GM music in games like Duke3D and Descent sounds the same.
Might the problem have something to do with my Multimedia settings in Control Panel (below)? However, I tried all of the options with no difference in output.
Everything else installed and works fine, including the SB16 emulation for digital audio.
