Reply 20 of 24, by AxXxB
wrote:The problem relates to for example this quite unknown game, Superbike: World Championship (1998)
I think i found ISO of it (autorun window is look like this? http://static.old-games.ru/uploadedimages/201 … 719638d642c.png) and it uses 16-bit IS5 installer (and it works with Wrapper). To make sure this is 16-bit (may be this is some other version of game or not this game at all) you can upload SETUP.EXE in attachment.
So. It looks like something goes wrong when IS Wrapper was uninstalled. Let's try to fix it 😀
Could you export from regedit these registry nodes?
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NtVdm64\
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\NtVdm64\
Also please upload contents of folder "C:\Windows\SysWOW64\InstallShield".
By the way, which version of IS Wrapper did you use?
wrote:I use this wrapper for nGlide test pack. Most games in this pack use IS5 32-bit. Some games use IS3 and IS5 16-bit.
There are some troubles (can't start 16-bit setup.exe from another program, like autoruns etc) but the wrapper don't break anything.
Wow, that was a great test of Wrapper! If you remember details of appeared troubles, it would be very appreciated.
Thanks you all guys!
